What is the dvd upscaling like and how does it compare to other models such as the LG BD390 or Sony BDP-370?
stephentw said:Not sure if I'm going mad but I'm pretty sure I've got mine setup right to output video from the main output and audio only from the second but my amp isn't picking up any audio at all, it's an Onkyo 705. It works fine if there's no 3d involved (although I did notice my amp was showing the sound as multi channel pcm instead of either dolby true hd or dts hd master) but as soon as 3d comes into play I get a picture but no sound.
Can anyone help?
No, swap them at the player end i.e main hdmi to amp and secondary/audio hdmi to television.How do you mean, physically turn them around so the player end is in the tv etc?
stephentw said:It's set exactly like that I don't understand why its not working. I spent most of last night experimenting with settings but I can't seem to get it working.
I see you have the 606 which I presume isn't 3d compatible. Did you change any settings on this at all or only in the player? Maybe its a handshake issue as I do get flashing lights as though its trying to do something. Worked fine bitstream from the old bd30.
Got a price match from John Lewis for £207 delivered. Should be with me in next few days, will have a new toy until I make up my mind what telly should I get.
Who did you use to price match?
I brought the 310 couple of weeks ago but but had issues with it out putting sound to my onkyo 905 I had it working for all of 10 mins hd sound through hdmi 2 picture through hdmi 1 all good! Swapped hdmi over for another one couldn't get it to work again tried 4 different hdmi cable nothing! Couldnt get it to work again so I sent it back. Problem is I need a blu ray player with 2 hdmi's and the only other one I found is the oppo which is a bit to much money! So if people have found a way for this to work with the onkyo amps could you let me know many thanks!
