Panasonic dmp-bdt 110 owners thread
Discussion in 'Blu-ray & DVD Players' started by golden phoenix, Aug 24, 2011.
  1. Bald Monkey
    Bald Monkey Member
    Aug 11, 2006
    7,122
    +1,109
    Probably because AFAIK the LE40C650 doesn't display at 24Fps.. ;)
  2. sbrads
    sbrads Member
    Jun 29, 2008
    41
    +4
    Well, the manual quotes 1080/24p as compatible. I think it's just me not liking 24p as reproduced in the home, it's different to the cinema which isn't perfect either but we're used to it.
  3. Vyse
    Vyse Member
    Jan 23, 2007
    73
    +7
    Anyone else noticing problems with playing DVDs on this player. I have been going through some of my Simpsons DVDs lately and they just dont look as sharp as when using my normal DVD player. I think the player may be trying to upscale the DVD, can I stop it from doing this?
  4. normsland
    normsland New Member
    Jun 2, 2011
    4
    Hello all. Please can anyone tell me if the UK version, the DMP-BDT110EB plays .avi files (Divx,Xvid) from the front USB port and/or the network share. After reading thru forums there's a lot of confusion of whether it does or not. It seems to suggest that it does from the panasonic.co.uk website. Please can someone who owns this great bluray player, has the latest firmware test this and let me know.
    Cheers, Norm :)
  5. Jason Shouler
    Jason Shouler Member
    Jan 8, 2011
    2,135
    +163
    Personally, I don't bother with the front USB (FAT32 issue) but have you not read posts # 71 - 85 :confused:
  6. normsland
    Jun 2, 2011
    4
    Hi Jason, Thanks for replying. Yes sorry like I said I got a bit confused. It seems that over in the US Panasonic don't ship any Bluray players with DivX because of licensing costs. Anyway found a reply on the BDT310 Now Available thread. The only reason for asking is some of my back catalogue is stuck as avi's. Going forward I'll play most files as mkv/m2ts on my Sony Bravia telly. Thanks
  7. mabuk
    mabuk Member
    Sep 4, 2007
    149
    +23
    If you format your USB drive with exFat then there are no (practical) file size restrictions. I successfully played a 6GB MKV using this method.
    if you still have Windows XP then you will need the following update for exFat to be recognised: Update for Windows XP (KB955704) Description of the exFAT file system driver update package
  8. Jason Shouler
    Jan 8, 2011
    2,135
    +163
    Sorry, keep forgetting this is an international Forum :blush:
    I find my UK model plays just about anything :smashin:
    The only real problem I have is with buffering (stuttering) problems which can affect some larger mkv files (especially high bit-rate 3D)
  9. mtunreal69
    mtunreal69 Member
    Mar 6, 2008
    658
    28
    +62
    I have also noticed that DVD's don't look as good as they should and tend to have a lot of ringing due to the poor upscaling. I'm using the drive in conjunction with my Panny GT30 so isn't an issue arising from the panel as all my other players reproduce the material fine.
    The unit is also whisper quiet. For those users who have a noisy unit, my see if where you are placing the player is solid, as some hollow tables can really hum.
    What I would like to know, is their anyway to set the player to source resolution? I don't want the BDT110 to touch the material, as i want my video processor to handle it for better picture quality.
  10. Jason Shouler
    Jan 8, 2011
    2,135
    +163
    There are a fair few options within "DISPLAY" (on remote). You'll probably want to make sure they're all turned off (or set to 0).
  11. mtunreal69
    mtunreal69 Member
    Mar 6, 2008
    658
    28
    +62
    I've played around with all those and feel its just to do with poor upscaling. Witnessed it a few times before, especially with old consoles being upscaled through my AVR. The DVDO edge however handles them much better.
    Don't suppose their is anyway to set native on the player, bit of a shame as I was hoping to use it as an all rounder.
  12. Viking61
    Viking61 Active Member
    Dec 5, 2007
    1,496
    116
    +701
    My player downloaded firmware version 1.70 this evening. Seems to be something new under Viera Cast called Marketplace.
    Time for you guys with the enhanced firmware to caugh up another ten Euro for an updated version. :cool:
    • Thanks Thanks x 1
  13. RobinDB
    RobinDB Member
    Dec 25, 2008
    331
    +27
    what is the "enhanced firmware" ?
  14. Viking61
    Dec 5, 2007
    1,496
    116
    +701
    Firmware to make your player regionfree for DVD and blu-ray.
  15. golden phoenix
    golden phoenix Active Member
    Aug 29, 2005
    9,203
    +1,273
    firmware update available ver 1.70
    VIERA CAST™ services has been upgraded to VIERA Connect™
    Network connectivity in a DHCP environment
    Playability of MKV file and other improvements
    for 110
    full list of update features to date
    viera connect is far superior to cast!
    • Thanks Thanks x 2
  16. Hamiltonian
    Hamiltonian Member
    Apr 15, 2008
    28
    3
    +4
    Hi all
    BD110 initial thoughts:
    picked it up this week, and plugged in the LAN last night (using d-link 'ethernet over mains cable').
    the player found my network, NAS etc without issue or intervention on my part (and I discovered my NAS was running twonky server, so was able to play music, not tried the video serving yet).
    auto download of f/w 1.7 went ok (d/l took a good 20 minutes though...)
    The Connect service looks like it has potential, but quite slow to navigate between each 'tablet', and you-tube was woeful. might be my ethernet setup though. Quite like being able to run Shoutcast radio, although slight overkill compared to plugging my aging Palm TX running pTunes into my amp.
    Quite liked the picasa wallpaper. No sight of BBC iPlayer yet though :-(
    have spun a couple of DVD's through the player, and have to say, wasn't exactly blown away by the picture quality. First step was to turn off all the picture processing, but looks like some proper tweaking and testing will be required to get something satisfactory.
    will hopefully be more impressed when Lovefilm send my first blu-ray.
    cheers
    h.
  17. bluepowell
    bluepowell Member
    Dec 3, 2008
    53
    HI.
    I've tried to use the DLNA thing to play mkv files, but the player cannot see them, although it could see and play AVi's. So i put the mkv (7gb) on an 8gb usb stick and it played fine. Was now thinking of getting an external HDD to store MKV's on, rather than playing around with the network sire of things (seems that it will be jerky over the network anyway), so has anyone used a HDD, or what would you recommend? Or should i just get a 32 gb usb stick as i cannot see that any mkv file will be bigger than that?
  18. Jason Shouler
    Jan 8, 2011
    2,135
    +163
    It has a major problem acting as a DLNA client.
    You need to read post #85 and before for the solution.
  19. fiatturbo
    fiatturbo Member
    Jul 11, 2008
    30
    Does the 110 put out DTS-MA over optical? over HDMI it is ok.
  20. Andori
    Andori Member
    Dec 7, 2006
    1,287
    63
    +204
    No player will output DTS-MA over optical due to bandwidth limits. They will send DTS core.
    • Thanks Thanks x 1
  21. golden phoenix
    Aug 29, 2005
    9,203
    +1,273
    correcto mundo!
    • Thanks Thanks x 1
  22. derek S
    derek S Member
    Oct 3, 2011
    15
    3
    Hi, I'm having major problems with lipsync on an LGBD660 which does not have audio delay so thinking of changing out for BDT110. Can you advise the max setting in ms for audio delay in the menu?
    (My sorry story here http://www.avforums.com/forums/lg-f...vise-watch-dvds-pcm-stereo-cure-lip-sync.html)
  23. Jason Shouler
    Jan 8, 2011
    2,135
    +163
    It's 250ms.
    However, my experience is that it often needs to be predictive ;) since it's really the video that needs delaying :D
  24. Zaichik
    Zaichik Member
    Mar 5, 2002
    907
    +28
    I've just (finally) had a response from Panasonic about my "fan" noise issue - they just say it's normal and disc dependent. I'm not happy because, on discs by one particular studio, the noise is horrendous - like the drive on the Xbox 360 or fan on the original PS3 at full tilt.
  25. golden phoenix
    Aug 29, 2005
    9,203
    +1,273
    had my amp firmware upgraded and all my audio woes were solved! upgraded my 110 aswell..to cover all bases and now have it wired to my router! need to still buy a memory card for local storage..any recommendations?
  26. DarenD
    DarenD Member
    Jun 13, 2009
    2,124
    +202
    Cant go wrong with Sandisk IMO.
  27. golden phoenix
    Aug 29, 2005
    9,203
    +1,273
    is that secure digital !?
  28. DarenD
    DarenD Member
    Jun 13, 2009
    2,124
    +202
    Sandisk is the manufactuer
    Secure Digital is the format
  29. mtunreal69
    mtunreal69 Member
    Mar 6, 2008
    658
    28
    +62
  30. golden phoenix
    Aug 29, 2005
    9,203
    +1,273
