Pace Sky Box stuck in standby
Discussion in 'Sky Forum' started by barachello2000, Oct 16, 2006.
  1. barachello2000
    barachello2000 Member
    Mar 28, 2005
    280
    I did a quick search but did not find anything really related, so sorry if this is a repeat !
    Basically my Pace digibox turned itself off tonight, and would not come out of standby. When this has happened in the past, I would just unplug it and leave it for 20 mins and then plug it back in and all would be ok. Not this time. :mad:
    It is yet to come out of standby, I have now had it unpluged for an hour while I have been trawling the net.
    What I am looking to know is, if I try a forced software download, and that is unsuccessfull, is another option to try to swap out a psu from another pace box ? If so, how easy is that likely to be - is soldering required ?
    But most importantly, any help or suggestions, greatfully received, as my wife and kids are beginning to do my nut in !!!!!
  2. davemurgatroyd2
    davemurgatroyd2 Active Member
    Dec 26, 2004
    7,219
    +1,102
    See this site for repair kits/replacement PSUs depending on model (should be on white sticky label on bottom of box BSKB???? - about third of the way down the page
    http://www.satcure.co.uk/accs/page12.htm#pacekits
  3. Inactive
    Inactive Member
    Oct 1, 2006
    658
    28
    +40
    FleaBay replacement, or possibly the sale pages on here.
  4. JayCee
    JayCee Active Member
    Jan 20, 2004
    15,774
    +1,581
    The Pace boxes don't have a separate psu like the Grundig and don't usually give problems so I wouldn't go down that route.
    If a forced software update doesn't cure it I'd think about binning it and just buy a replacement.
  5. RichardBoult
    RichardBoult Member
    May 11, 2004
    659
    +18
    My old pace went wrong years ago and it was the tuner that had packed in!
