Optoma hd81 serial cable help!!!!
Discussion in 'Projectors' started by thecornfords@go, Mar 10, 2011.
  1. thecornfords@go
    thecornfords@go Member
    Jan 4, 2008
    689
    +24
    Hi guys wondered if anyone here knows what wire is not needed on a 9 pin serial cable between the processor and the projector? i've run a cat5e cable which has 8 wires but the serial cable has 9 wires. just wondered if all 9 wires are used by the projector? many thanks, chris.
  2. legriffe
    legriffe Member
    Aug 1, 2006
    606
    +24
    I enquired about this not to long ago when i was thinking about buying the HD81LV, spoke to Richard from Optoma re-sales (nice guy) he asked one of his engineers for me and i was told it only used a couple of pin connections.
    Hope this helps.
    • Thanks Thanks x 1
  3. AussieTech
    AussieTech Member
    Sep 9, 2008
    125
    +8
    You just need 3x wires for RS-232 (serial).
    Does the processor and the projector both have males 9-pin connectors? If so then you can make up a straight-thru cable.
    Pin 2 = Rx
    Pin 3 = Tx
    Pin 5 = Gnd
