Optoma hd33 / hd300x owners thread - Part 3
Discussion in 'Projectors' started by the_dude2, Sep 30, 2012.
  1. toddy28
    toddy28 Active Member
    Aug 20, 2007
    3,134
    +344
    If you would like to do a swap for the older style glasses I'm your man , ;)
  2. emporer
    emporer Well-Known Member
    Mar 10, 2005
    8,087
    +1,624
    I took them out and tried them on quickly, nice and comfy, i'm curious to their claims of being the brightest glasses they have done yet, that would work for me, brighter the better.
  3. toddy28
    Aug 20, 2007
    3,134
    +344
  4. nkhan
    nkhan Member
    Oct 20, 2010
    2,394
    +95
    Not cheap at the moment, would be interesting to know if they are actually better than the RF or is a question of preference
  5. toddy28
    Aug 20, 2007
    3,134
    +344
    there still rf just a diffrent model like a mk2 :D
  6. emporer
    Mar 10, 2005
    8,087
    +1,624
    Just rigged mine up, surprise to see firmware c05, going to try the keystone issue first to see if its fixed.
  7. emporer
    Mar 10, 2005
    8,087
    +1,624
    Good news, the new firmware fixes the keystone ripping problem.
  8. emporer
    Mar 10, 2005
    8,087
    +1,624
    Just put on Avatar, 3d is as expected, no ghosting I can see, glasses do let in a lot of light which is nice, the image is really nice with these, however I have noticed a very quick reddish flash on the specs every minute or so, very annoying I must say, any ideas?
  9. emporer
    Mar 10, 2005
    8,087
    +1,624
    The reddish flash turned out to be a hdmi issue I think, I noticed when I took the glasses off it still happened on the screen, so I flicked the AVR to Sky and then back to the BR deck to re-initialise the hdmi handshake and it solved the problem, tried a few discs and all looked great, watched a bit of Madagascar 3 which looked really nice, bright and vibrant and lots of pop, the trailer on the disc for Rise Of The Guardians looked spectacular, that is a must have disc if it looks as good as that did.
  10. toddy28
    Aug 20, 2007
    3,134
    +344
    Think its time to send mine off then , cheers
  11. emporer
    Mar 10, 2005
    8,087
    +1,624
    I must point out that the new rf glasses I thought were superb, it does appear that they let alot of light in, it felt almost like wearing passive glasses, plus I couldn't see any ghosting at all.
    • Thanks Thanks x 1
  12. museumsteve
    museumsteve Active Member
    Jan 28, 2001
    6,897
    +687
  13. emporer
    Mar 10, 2005
    8,087
    +1,624
    But on Amazon.com they are about $78, why do we constantly get ripped here?
  14. museumsteve
    Jan 28, 2001
    6,897
    +687
    I guess as Optoma dont retail directly, it's up to the retailers. New/low stock items, high/premium price.
    Definitely keen to try a pair though :cool:
  15. harani
    harani Member
    May 7, 2009
    10
    Can any owners advise whether the RF emitter for this Projector will talk to RF glasses from other systems. specifically i'm looking at getting a 6300 series Samsung TV later this month and it would be great to get a set of glasses that would work with both devices
  16. emporer
    Mar 10, 2005
    8,087
    +1,624
    Don't the Sammy sets all work on bluetooth now?
  17. harani
    harani Member
    May 7, 2009
    10
    yes, the 6500 "E" series are bluetooth. is that different to the "RF" output of the Optoma IR > RF adapter unit ?
  18. emporer
    Mar 10, 2005
    8,087
    +1,624
    I'm assuming so, if not directly different it will more than likely have different frequencies.
  19. toddy28
    Aug 20, 2007
    3,134
    +344
    The rf glasses will not work on a Samsung TV as there Bluetooth but it doesn't matter as you won't be watching any 3d on your tv , trust me I have not used the 3d on my Samsung TV since I got my hd33 over a year ago
    The difference is huge between a TV and a projector for 3d
  20. Mensy
    Mensy Active Member
    Mar 22, 2008
    10,950
    +590
    Hi guys how does this projector rate against a Optoma hd65 with 3dxl ? anyone owned the previous and now upgraded to this ? ive just bought the 3dxl but i think i wanna upgrade
    Whilst the 3D is good on the 3dxl i still think i missing alot of brightness, detail, more depth and pop but i dunno if im just expecting more from 3D but in reality thats the best it gets if you get me lol
    • Thanks Thanks x 1
  21. toddy28
    Aug 20, 2007
    3,134
    +344
    I had a hd67 and 3dxl and its well worth the upgrade , but only if your using a blu ray source for 3d , if your using sbs mkv films the quality is the same , I only use blu ray now and won't watch sbs stuff
    The 2d upgrade to 1080p is good as well
  22. emporer
    Mar 10, 2005
    8,087
    +1,624
    The HD65 has slightly less lumens output, although its not much less, I doubt you would notice much difference in that area, 3d will be the same more or less as with your 3dxl, what will be much better is the detail, and how vibrant the image is on the HD33.
  23. toddy28
    Aug 20, 2007
    3,134
    +344
    3d is worlds apart , its jaw dropping with the right film , tangled for example look really good on my 3dxl , and bloody amazing on the hd33
    The 3d effect is the same as in depth and pop
    Coming as a past owner I would say you would not regret upgrading for 1 second I didn't , even the wife was wow that's better then the old one and she doesn't give a monkeys about my av gear she would be happy with a black and white portable tv
  24. emporer
    Mar 10, 2005
    8,087
    +1,624
    Agreed, its a worthwhile upgrade, especially as they are now £998 with the new rf glasses and the latest firmware which fixes previous issues.
  25. hippak
    hippak Member
    Nov 3, 2012
    4
    Hi All.
    Just purchased an HD300x this week and am looking for 4-6 pairs of inexpensive 3d glasses. I looked on ebay and the ones people usually recommend seem to not be compatible with the HD33/HD300x as of October:
    2 Pairs 3D DLP Link Glasses for Optoma HD33 HD36 HD65 HD66 HD5101 Projector New | eBay
    Any idea why... what would have changed on the Optoma's that would make them incompatible?? I'm looking at these aswell but am kind of confused as they need an emitter?
    Fit All 3D Glasses 4 and Emitter for DLP TV's Projectors HD33 HD300X Etc | eBay
    Can anyone recommend some glasses?
    Thanks in advance!
  26. Rob127
    Rob127 New Member
    Oct 23, 2012
    94
    +7
    id get vesa rf glasses if i were you not dlp link
    what country are you in ?
    rob
  27. hippak
    hippak Member
    Nov 3, 2012
    4
    I'm located in the netherlands.. but I live between my homes in Netherlands/Canada/USA/London that I can ship to if needed.
  28. Rob127
    Rob127 New Member
    Oct 23, 2012
    94
    +7
    lol, thats like my missus..but now shes seen it, shes impressed, :smashin:
  29. emporer
    Mar 10, 2005
    8,087
    +1,624
    Your 2nd link, those glasses should work with the 300x.
  30. hippak
    hippak Member
    Nov 3, 2012
    4
