Onkyo VTuner tip - 509/609/709/809
Discussion in 'Integrated Amplifiers & Receivers' started by whooshavf, Mar 20, 2012.
  1. whooshavf
    whooshavf Member
    Sep 30, 2009
    105
    +4
    For those of you with a LAN connected Onkyo using vTuner
    Onkyo Radio Guide
    which allows you to search, add, modify favourites to your amp's vtuner menu
    I had my amp disconnected and powered down for 4 days and the amp ID# changed - so I lost all my favourites and vtuner would not update the amp
    you can find it on the NET Setup menu as the last item (Mine's a 709)
    • Thanks Thanks x 2
