Onkyo TX-NR609 Black Network AV Receiver
Discussion in 'Expired Bargains' started by davidm2, Feb 24, 2012.
Thread Status:
Not open for further replies.
  1. davidm2
    davidm2 Member Assured Advertiser
    Sep 14, 2007
    599
    +97
    Onkyo TX-NR609 Black Network AV Receiver Amp 3D Ready HDMI 4K 1080P 7.2Ch THX/Dolby/DTS
    Brand New Product - 1 Year Warranty - Exclusive AForums Offer - While Stocks Last
    Normal Retail Price: £419.99 Inc VAT
    AVForums Price: £359.99 Inc VAT
    AVForums Members are entitled to Free Delivery - (Mainland UK) or Reduced Carriage (Other Areas)
    To order: Please post below, and we'll contact you by PM
    How do you replace an award-winning product? It's not been easy but with the Onkyo TXNR609 they've kept all the best bits of the top selling TXSR608 but added even more temptations!
    Best of all, the new TXNR609 now comes with network compatibility. It wasn't so long ago that this feature was reserved for the £1000 plus models but now you can get all the benefits for far less. Simply connect to your home network using an Ethernet connection and you can access Internet radio sites such as last.fm and stream music via DLNA from other sources such as your laptop or NAS drive. Furthermore, the TXNR609 is also the first Onkyo receiver to feature the popular Spotify music streamer built-in (premium account required). The new TX-NR609 also adds 4K video upscaling by Marvell Qdeo, an iPhone/iPod compatible USB port at the front and sleek new styling.
    [​IMG]
    In other respects, the new TX-NR609 mirrors its class-leading predecessor. As before, no fewer than 6 HDMI inputs are on hand, with one being front-mounted for occasionally connected sources such as HD camcorders or games consoles. Not only are these sockets more than capable of handling the most complex of home cinema systems, they are also fully compatible with 3D TV. A still highly unusual feature but welcomed by many is the VGA PC input. This means that you can easily route your PC's video signal through your home cinema system. You'll also find twin optical and twin coaxial digital inputs and the full complement of component, composite and RCA phono sockets that you'd expect. New to the TX-NR609 is a front-mounted USB socket. It might not look much, but this little socket will transform the sound quality from your iPod or iPhone. By connecting to the USB, you'll benefit from a digital connection. This gives a direct signal and, hence, purer sound quality than using a conventional dock or analogue input. If you don't have an iPod or iPhone, the USB socket will also accept music signals from other MP3 players or multi-media devices. Finally, the TXNR609 features a universal port at the back for Onkyo iPod dock connection or DAB+ tuner upgrade module.
    Then there's the processing power to consider. As you'd expect, DTS-HD Master Audio, DTS-HD High Resolution Audio, Dolby TrueHD, Dolby Digital Plus and Dolby Pro Logic IIz are all standard. In addition to this, the latest Onkyo AV receiver comes with Marvell Qdeo 4K video upscaling. Going one stage further than conventional 1080p upscaling, the processor has the power to upscale to twice that level! Known as 4K because of the horizontal pixel count of 1080p TV increasing from 1920 to around 4000 (there are several formats all offering slight variations). Currently 4k TVs and monitors are specialist items but, watch this space; prices are coming down all the time. At the moment there are already 4K videos available over the internet but with the TX-NR609 the upscaling ensures, whatever the format, you're all set for the future of 4K. In recognition of the Onkyo's outstanding ability, it has been awarded THX Select2 Plus Certification, meaning it meets exacting standards set by the Lucas Film studios - again, that's highly impressive given the price.
    [​IMG]
    When it comes to setting the TXNR609 up, the standard Audyssey 2EQ system is there to help out. This not only automatically calibrates speakers, but also corrects room acoustic issues. The upshot of this hi-tech processing is ideal sound quality, whatever the room.
    Finally, there's the sound quality. There's little doubt here that the TXNR609 is still one of the best in its class. If you were wondering what the "7.2" channel output meant, that's explained by the TXNR609's twin subwoofer outputs. When used in this way you get a better spread of bass and can use two smaller, but "faster" sounding subwoofers for a tighter, better controlled bass. The powerful sound of this amplifier is helped still further by the three-stage inverted Darlington circuitry, jitter-cleaning technology, WRAT (Wide Range Amplifier Technology) Pure Audio and Double Bass Function - not to mention the impressive 120 watts available to each speaker.
    Now with Network ability, including Spotify, 4K video upscaling and smooth new looks, the Onyko TX-NR609 has done the seemingly impossible and raised the bar still higher. What a result!
    • THX® Select2 Plus™ Certified
    • HDMI® Support for 3D Video and Audio Return Channel
    • Network Capability Delivers Internet Radio and Network Audio Streaming via Ethernet
    • 4K Video Upscaling and Processing via Qdeo™ Technology
    • Audyssey DSX™ and Dolby® Pro Logic® IIz
    • Thanks Thanks x 1
  2. johnbusby
    johnbusby Member
    Aug 29, 2009
    2,572
    71
    +90
    Still available?
  3. davidm2
    Sep 14, 2007
    599
    +97
    Yes, it's available.
    Please could you PM me your name and contact number, and I can arrange someone to call you if you're interested in this.
  4. skronk
    skronk Member
    Jan 7, 2010
    435
    28
    +41
    I may be interested also but live on a Scottish island. Post to here would be prohibitive.
    Would you post to mainland free where I can pick up ?
    Regards
  5. davidm2
    Sep 14, 2007
    599
    +97
    Yes, that will be fine. We can arrange a free delivery via mainland for you.
    If you drop me a pm with your contact details - and we'll arrange a call back.
  6. swiss_tony
    swiss_tony Active Member
    Jul 28, 2007
    3,668
    +188
    What is the delivery time usually as I am looking to buy one?
    • Thanks Thanks x 1
  7. skronk
    skronk Member
    Jan 7, 2010
    435
    28
    +41
    Think you might have to post your question under "Bargains"
    Thats where I found the offer !
    Good luck
    • Thanks Thanks x 1
  8. davidm2
    Sep 14, 2007
    599
    +97
    Typically next working day if you place the order before 5:30 today.
    Edit: I need to pass some additional information to you Swiss_Tony - could you clear some inbox space please? Thank you :)
  9. swiss_tony
    Jul 28, 2007
    3,668
    +188
    Done, does that include Saturday delivery?
  10. dbn
    dbn Member
    Feb 1, 2005
    1,126
    48
    +32
    :hiya:
    Do you have any deals on the Onkyo 709, looking for 2 Hdmi's out.
    thanks
    dean
  11. azkhan
    azkhan Member
    Sep 17, 2005
    56
    +6
    I am very interested in looking to buy this Amp. please can you PM me the details on how i can order this?
    Thanks.
    Azkhan
  12. davidm2
    Sep 14, 2007
    599
    +97
    No problem - please PM me your real name, email and a contact telephone number - and we'll ring you to sort this out :)
  13. davidm2
    Sep 14, 2007
    599
    +97
    Indeed - and that should be with you tomorrow :)
  14. Stevep81
    Stevep81 Member
    Mar 2, 2012
    22
    3
    Hi, is the deal still available for this one???
    Think I might be interested!
    • Thanks Thanks x 1
  15. Rawschach
    Rawschach Member
    Nov 8, 2004
    788
    46
    +108
    have you any of these left?
    • Thanks Thanks x 1
  16. davidm2
    Sep 14, 2007
    599
    +97
    Yes of course - if you can both PM me your name, telephone number and email - We'll get back to you as soon as possible.
  17. davidm2
    Sep 14, 2007
    599
    +97
    I'll check into this and see what's possible.
  18. Bigrobbo
    Bigrobbo Member
    Mar 2, 2012
    9
    What speakers would you recomend with the onkyo 609?
  19. Alan_Be
    Alan_Be Member
    Oct 16, 2002
    71
    +6
    David,
    If there are any left consider me interested in one!
    Cheers,
    Alan.
    • Thanks Thanks x 1
  20. bones666
    bones666 Member
    Feb 29, 2012
    2
    I'd definitely be interested in this one, if there are any still available of course?
  21. davidm2
    Sep 14, 2007
    599
    +97
    If you can PM me with your real name, telephone number and email - I'll arrange someone to contact you
  22. SGrrrrrr
    SGrrrrrr Member
    Mar 5, 2012
    Hi, I would be interested in talking to someone about one of these, but I cannt PM at the moment, perhaps if you PM me, I may be able to reply. Thanks
  23. fizl
    fizl Active Member
    Apr 21, 2006
    2,158
    +465
    SGrrrrrr, as you are a new member, you have to put in a request to enable PMs. I think this is via your profile page settings
    shaz
    • Thanks Thanks x 1
  24. davidm2
    Sep 14, 2007
    599
    +97
    If you follow fizl's advice - hopefully you should be able to PM me.
  25. Stuart Wright
    Stuart Wright AVForums Founder Staff Member
    Jan 24, 2000
    11,406
    Media:
    11
    Albums:
    171
    +6,877
    Click here to visit your profile page and join the messaging enabled group.
    I regret having to have this restriction in place, but the Lichfield scammers (the Ainsworth family and some of their friends) are still trying to scam people despite having a court date.
    • Thanks Thanks x 2
  26. lfc2011
    lfc2011 Member
    Aug 13, 2011
    49
    9
    any 709's available as a deal before i go get a avr3312?
  27. dbn
    dbn Member
    Feb 1, 2005
    1,126
    48
    +32
    :hiya:
    Any update on the 709, as i can get 1 from richer sounds for £599.00
    thanks
    dean
  28. Spy
    Spy Active Member
    Jan 6, 2004
    2,917
    +234
    Just wanted to say Thanks to David.
    Ordered one of these bad boys yesterday and it arrived this morning. Now I just need to set it up :smashin:
    • Thanks Thanks x 1
  29. bigmac21
    bigmac21 Member
    Oct 24, 2011
    5
    3
    I'd be interested in one too. I'll PM you.
    • Thanks Thanks x 1
  30. davidm2
    Sep 14, 2007
    599
    +97
    I'm not at work today - but will try and find out about this for you.
Thread Status:
