Onkyo Main Firmware and DSP Updates
Discussion in 'Integrated Amplifiers & Receivers' started by Crustyloafer, Apr 8, 2008.
  1. Donali
    Donali Member
    Jan 22, 2005
    2,229
    71
    +103
    IIRC this is the loader version. Follow the instructions in the file you downloaded and you should be OK.
  2. TomLeeChan
    TomLeeChan Member
    Sep 19, 2010
    30
    Well I press "display" and "standby" it says 1.04, but if I hold "enter" and turn on the receiver it says that I have 1.01 ...
    Anyway I tried to install HDMI 1.02 and when I pressed "video update" is says: Run-time error 8002: invalid port number ... *** LOL???
    Am I missing something?
  3. Donali
    Donali Member
    Jan 22, 2005
    2,229
    71
    +103
    1.04 is your firmware, 1.01 is your loader version.
    Have you set the com port to Com 1?
  4. TomLeeChan
    TomLeeChan Member
    Sep 19, 2010
    30
    yes, speed 9600 (didnt change it)
    I connected the cable, press only once tuning up button, turn on, nothing happened
  5. Donali
    Donali Member
    Jan 22, 2005
    2,229
    71
    +103
    I'm at a loss now but I'm sure its just a communication error. Did you set the COM 1 vis device manager on your PC?
  6. namuk
    namuk Well-Known Member
    Oct 23, 2006
    21,586
    +4,009
    did it say this "MainUpdate Mode Ver.1.01/07615L" then your ok , it is just the version of the Amp updater..
    i also uploaded this Update instructions (Pdf format) if you do not have this version? RapidShare: 1-CLICK Web hosting - Easy Filehosting
    also the firmware has tobe in the same Directory as the updater , make a new folder and name iT "Firmware" and place all files in there.
  7. TomLeeChan
    TomLeeChan Member
    Sep 19, 2010
    30
    i am definitely doing something wrong because everytime pops out that error ... and yeah i got it set on com1 ...
    i don't know, i gave up, i'll just let it be on 1.04 ... at least i updated sdp ...
  8. carlosalberto
    carlosalberto Member
    Oct 19, 2010
    5
    I have an Onkyo TX-SR875, with firmware 1.01
    I find the necessary updates, I have the instructions
    Tank you
    Carlos
  9. Sammer
    Sammer Member
    Oct 12, 2005
    123
    16
    I have an Onkyo 603 from over 4 years ago....
    I have never done any updates...
    is it worth doing it?
  10. keyser
    keyser Member
    Jul 23, 2000
    887
    Has anyone done a update and the video output has stopped working? I have yet to isolate what parts of it don't work though.
    I´m thinking of going through the whole update proccess again.. what happens if one tries to install a firmware that is already installed?
  11. dUnKle
    dUnKle Active Member
    Jan 1, 2001
    9,953
    +359
    My firmware is 1.05
    My amp has recently been loosing its settings
    Each speaker reverts back to 0 with exception of sub which usually shows a figure so long it does not appear on screen
    I'm also unable to save settings getting message saying store failed
    Can this be fixed ?
