TheBlueFalcon
- Joined
- Mar 27, 2007
- Messages
- 4,888
- Reaction score
- 603
- Points
- 812
If it was me, I would try REW first. Although it will take more time/effort, it's the cheaper than spending money on something that may not be needed. If money really isn't a problem then there's possibly another option on the way, but not available right now - unless you want to replace the 5008 with a 5508 and Power Amp.
The only way to find out for sure if there could be any further improvement over XT32/Sub EQ HT is to measure what is going on in the room. If there are any excessive peaks then an Antimode should help, but if not, then it's not likely to make any difference at all. Unless things can be measured and compared, then you have to pay out to take chances on the possible options and trust your ears/brain to work out if it's an improvement or not.
Just one other thing, why would consider an AS-EQ1 when the 5008 has the same technology onboard?
