Old technics upgrade
Discussion in 'Integrated Amplifiers & Receivers' started by pdcelec, Jul 4, 2009.
  1. pdcelec
    pdcelec Member
    Jul 3, 2009
    2
    I have a Technics SU-X77 which i believe was the first surround system on the market. I am planning on an upgrade to new equipment but I am wondering if the speakers SB-C250 are still ok to use with the new amps. The speakers till sound great in stereo. Any opinions?
  2. davepuma
    davepuma Well-Known Member
    Jun 24, 2004
    17,319
    +3,167
    I would check the impedance rating (ohms) of the speakers first. I would imagine they are fine but it is best to check. Is the sub an active (powered) model that is connected via an RCA phono cable?
  3. pdcelec
    pdcelec Member
    Jul 3, 2009
    2
    The speakers are 8ohm. Active sub! this system was bought in 1986! I was just wondering whether to keep just the speakers as they are great sounding and could they incorporated into a new modern setup.
  4. davepuma
    Jun 24, 2004
    17,319
    +3,167
    8ohms will work fine and so will the active sub, providing it has RCA phono connection. I would imagine they can handle a modest amount of power too but a budget HD audio decoding receiver would be a good move e.g. Sony ST-DG820/ST-DH800, Denon 1610/1910, Yamaha 465/565, Onkyo 577/607, Marantz SR5003 etc.
