O2 Broadband DNS server problems!!!
Discussion in 'ISPs & The Internet' started by jimbob1010, Jun 26, 2008.
  1. jimbob1010
    jimbob1010 Member
    Mar 31, 2008
    171
    +13
    Has anyone with O2 broadband been having problems with the O2 DNS server or do they know anyone whos been having problems with the O2 DNS server.
    I've been having problems over the last 36 hours or so with the O2 DNS server and I am on the computer at my job.
  2. C225
    C225 Active Member
    May 15, 2006
    6,103
    +694
    I've been having problems with the o2 DNS for the last week or so as i was just getting a load of page time outs and the PS3 and Xbox wouldn't connect with DNS problems.
    Anyway i changed to openDNS and all is well again.
  3. macdaddy
    macdaddy Member
    Apr 13, 2004
    267
    +19
    Mine's fine although I did have problems when trying to use my Netgear router.
    Switched back to the O2 box and all is well again - blazing fast and no dropouts at all:thumbsup:
  4. C225
    C225 Active Member
    May 15, 2006
    6,103
    +694
    It's quite strange as from what i can work out you get assigned different DNS server depending on what ip address range you are on and the ip address changes according to the MAC address of the router so as for you changing router would mean you got a better ip addredd so asigned the better DNS servers.
  5. jimbob1010
    jimbob1010 Member
    Mar 31, 2008
    171
    +13
    So would you recommend me trying the O2 box and seeing if that cures the O2 DNS problem?
  6. Uridium
    Uridium Active Member
    Jan 29, 2005
    14,359
    +1,881
    I found that if i used the O2 DNS servers from my Netgear router without spoofing the MAC address of my O2 router then i had lots of DNS issues and timeouts.
    As soon as i changed the MAC address of my Netgear router to that of the supplied O2 router then the DNS problems disappeared.
  7. MarkE19
    MarkE19 Moderator
    Aug 10, 2002
    15,868
    +2,083
    I am with o2 and use my own Netgear router. As Uridium I have set the MAC address from my o2 box to the Netgear and have not had any problems (so far :rolleyes: ).
    Mark.
  8. accyuklad
    accyuklad New Member
    Feb 13, 2008
    5,038
    +281
    i dont know how to change mac address on netgear on mine i just tryed the o2 box and its faster at pages how weird is tht
  9. C225
    C225 Active Member
    May 15, 2006
    6,103
    +694
    Gone back to the o2 DNS for the first time in a week and the problems seem to have gone for me now
  10. macdaddy
    macdaddy Member
    Apr 13, 2004
    267
    +19
    Nope, tried that and still had problems!
    O2 box seems to work well with all my gear so at the moment I'm happy to stick with it..
  11. Chanser
    Chanser Member
    Apr 9, 2004
    1,823
    +220
    I'm using BT DNS servers at the moment.
  12. MarkE19
    MarkE19 Moderator
    Aug 10, 2002
    15,868
    +2,083
    If you are happy with the o2 box then I see no reason to swap it out for something else. I just kept my Netgear router as I already had several wireless devices setup on it. But if it dies I will just use the o2 box rather than buy another router.
    If you do want to use a Netgear (or whatever make) router with o2 then do a search on here as I have posted all the settings required to get it working.
    Mark.
  13. jimbob1010
    jimbob1010 Member
    Mar 31, 2008
    171
    +13
    I solved the DNS problem by changing the my router to the o2 router, so far so good I had no problems. I've had no disconnections and seem to be getting good speeds with the O2 router.
  14. williemaykit
    williemaykit Member
    Jan 8, 2006
    1,311
    +170
    I had issues with Be/O2 DNS servers using the BE Box. Did a search on the BE forum. A few people there suggested switching to OpenDNS.
    Primary DNS is 208.67.222.222.
    Secondary DNS is 208.67.220.220.
    It works a treat. Instructions can be found here
    • Thanks Thanks x 1
  15. accyuklad
    Feb 13, 2008
    5,038
    +281
    mine is fixed now since i using o2 box
