Noisy mondeo
Discussion in 'Motoring' started by spocktra, Nov 16, 2005.
  1. spocktra
    spocktra Member
    Nov 22, 2004
    2,014
    48
    +41
    I get a low pitched whine when turning left could this be a bearing .mk3 mondeo.Got it booked in next week just wondered if anyone had heard the symptons before.
  2. Ayub
    Ayub Active Member
    Oct 15, 2003
    5,924
    +548
    easy to find out. Jack the wheel up. Push pull the wheels keeping your hands on the up 12 oclock and the other at the 6pm position. If you feel any play tis your bearings ( car) :smashin:
  3. spocktra
    spocktra Member
    Nov 22, 2004
    2,014
    48
    +41
    Apparently not a wheel bearing had a uneven tyre changed on the offside rear.This might give a clue to the problem?.Possibly a suspension fault.Garage i took it to seemed baffled.Sods law when the mechanic took it out ,no noise.Might have to bite the bullet and take it to ford- £70 an hour :eek: :eek:
  4. Layne RIP
    Layne RIP Member
    Sep 22, 2005
    708
    +16
    Is the noise only on hard turning?.. or whenever you turn... it could be the Power steering pump.. the bearings might be on their way out in that.
  5. spocktra
    spocktra Member
    Nov 22, 2004
    2,014
    48
    +41
    Normally on a 90 degree turn but it does sound like its coming from the rear.Then again these things can be misleading.
  6. Layne RIP
    Layne RIP Member
    Sep 22, 2005
    708
    +16
    the problem is with noises.. that unless you hear them in person... it's very hard to tell what it is.
