No volume control from spdif
Discussion in 'Windows' started by mrwideboy, Nov 2, 2007.
  1. mrwideboy
    mrwideboy Member
    Nov 2, 2007
    11
    Hi dude, I have been having sound problems when using MCE AND Spdif output, I am getting sound out of the sdiff output but have no control and can't adjust the volume. When I first installed MCE I think it did work but for some reason I cannot adjust the volume. I am pretty sure the volume is being adjusted form the standard stereo output.
    I am using an asus av8-vm with an on board sound max sound card with HD audio from analogue devices, the case is a zalman 160XT.
    I have done the usual things like drivers etc patchs, but i cannot for the life of me work out why.
    Any help please
  2. JonLeach
    JonLeach Member
    Sep 17, 2002
    731
    +21
    get yourself volumetracker and link it to the WAve device that should do the trick for you, or use the volume on your Receiver
    Jon
    • Thanks Thanks x 1
