Newbie Confused Over Formats etc.
Discussion in 'Integrated Amplifiers & Receivers' started by Plivez, Feb 24, 2012.
  1. Plivez
    Plivez Member
    Feb 23, 2012
    Hi Guys, great forum!
    I have just purchased my first surround sound set up;
    Sony STR-DH820 AV and Boston Accoustics SoundWare XS 5.1.
    So far this is being fed by my Virgin V+ box and Apple TV.
    Depending on what channel I am watching I get a variety of format names appearing on the AV display.
    They are as follows:
    LPCM 48
    Dolby Digital 2.0
    Dolby Digital 5.1
    I have a number of 'sound field' options:
    AFD Auto
    Multi ST
    HD DCS
    PLII MV
    NE06 CIN
    I currently understand none of this, should I be choosing the sound field option based on the format coming in? If so what goes with what.
    I have read the manual a few times but its beyond me at the moment.:confused:
    Would appreciate any advise.
  2. scottthehat
    scottthehat Active Member
    Jan 6, 2012
    8,181
    +1,228
    First of welcome. 2nd it won't take long before you know what's what. If your watching tv alot of that is only 2 stereo so personally i would use dolby pro logic 2 as this will make 2 stereo in to 5.1 . And then some stuff on tv is dolby digital 5.1 so leave that as it is unless you add more speakers then you can use other modes like dolby pro logic 2x as this will make 2 stereo in to 7.1 and 5.1 into 7.1. And depending how you like your music just experiment with the different modes, i normally use 2 stereo or all stereo. Also the manual should explain what each mode is for more or less. For all of my tv stuff i have started using neural thx 7.1 and i found it to be the best. So its all about trying and seeing what you like.
  3. iaint
    iaint Member
    Jul 4, 2011
    633
    28
    +90
    Hi.
    LPCM 48 is basically just a way of saying "Stereo", but not compressed; your Virgin box/AppleTV probably decoded it already. 48 is just the sampling rate...
    Dolby Digital 2.0 is another way of saying "Stereo", just compressed; left for your AVR to decode.
    Dolby Digital 5.1 is also compressed, but consists of 5 main channels (left, right, centre, rear left, rear right) and 1 sub channel (LFE).
    Pick a sound field that sounds good; PL2 MV is a good start, but try the others...
    Regards, Iain.
  4. Plivez
    Plivez Member
    Feb 23, 2012
    Thanks for the quick replies!!
    So LPCM & Dolby 2.0 can both be converted using the sound fields into surround sound. Is that a genuine surround sound?
  5. jason1wood
    jason1wood Member
    Feb 5, 2006
    2,452
    +140
    It's not genuine but pseudo surround. Still sounds great though, when watching my Sky HD and only getting a stereo signal eg. Left and right speaker sound I put mine onto Neo6 Cinema yours is NEO6 CIN, this gives me surround sound out of all 5 speakers instead of 2.
    Don't worry you'll get the hang of this soon.
  6. scottthehat
    Jan 6, 2012
    8,181
    +1,228
    lpcm can be true surround up to 7.1. And as said any of those modes will convert 2 channels into 5 channels plus sub.
  7. Plivez
    Plivez Member
    Feb 23, 2012
    Thanks again. How much action should I expect from the rear speakers? There doesn't seem to be that much generally. How do you go about increasing it?
  8. scottthehat
    Jan 6, 2012
    8,181
    +1,228
    it depends on what it is your watching some stuff is just mental in the back speakers. And have you set audessey up yet.
  9. Plivez
    Plivez Member
    Feb 23, 2012
    Audesey?
    Is that the auto calibrate? I did that. Although have since done a manual set up to correct the distance settings. I have also increased the decibels on the rears in attempt to get more from them.
  10. scottthehat
    Jan 6, 2012
    8,181
    +1,228
    That's right audessey is the calibration. And sets the speaker to a specific level what is called studio reference as in what's its ment to be played at in the studio end its sets the speakers at the same level for the listening position where you placed the Mic and at 0db on the amp volume that should then be studio reference volume so you adjusting them won't help but its what makes you happy. Also reference is only for films.
  11. NoOneNew
    NoOneNew Member
    Jan 18, 2012
    183
    +20
    LPCM means that the source feeds a decoded signal to your amp, no matter what the original format (could be 2-channel stereo, Dolby, DTS-MA, whatever). All the amp has to do is pass it through its digital-to-analog converter (DAC) and play it. The number (eg 48) depends on the bitrate, bigger is better.
    Dolby Digital is a sound format. "X.Y" numbers are the numbers of channels the sound was originally encoded in. The amp must first decode the signal before converting it to analog. There are other formats also, one of the sticky threads in this forum explains them all.
    For an explanation of the Sony soundfields, see
    http://www.avforums.com/forums/av-a...nys-hd-d-c-s-against-plii-movie-sony-avs.html
    Any more questions, feel free to ask.
  12. Plivez
    Plivez Member
    Feb 23, 2012
    Thanks for the explanations.
    All becoming much clearer.
    Have been spending hours playing the cinema sound tests on youtube through my apple TV, great fun!!
