New Revo AXiS owner-can I stream my from my iTunes library?
Discussion in 'Streamers & Network Music Players' started by Azzin, Feb 20, 2011.
  1. Azzin
    Azzin Well-Known Member
    Nov 5, 2005
    23,860
    +3,078
    Hi all,
    SWMBO has bought me a Revo AXiS for my birthday and I'm really pleased with the unit, but I've just tried to configure it to stream music/playlists from my iTunes library, but it looks like it only streams from a Windows PC if you use WMP.
    Is that right, or is there some way I can stream my iTunes playlists using the AXiS?
    Cheers.
    [Edit] - Just noticed this on the Apple site:
    I have an iPad, which I guess I could dock and use, but would rather stream direct from my PC.
  2. Crocodile
    Crocodile Well-Known Member
    Nov 4, 2002
    12,729
    +2,613
    Have a Google for "Free MAC UPnP".
    • Thanks Thanks x 1
  3. Azzin
    Nov 5, 2005
    23,860
    +3,078
    Thanks, I'm using Windows 7 if that changes anything?
  4. Crocodile
    Nov 4, 2002
    12,729
    +2,613
    Apologies, I somehow assumed you were using a Mac! :suicide:
    I'm still out of my depth as I have no iTunes knowledge but this seems to offer a free solution for non-DRM material. I dare say a Google search will find other options.
    • Thanks Thanks x 1
  5. Azzin
    Nov 5, 2005
    23,860
    +3,078
  6. Azzin
    Nov 5, 2005
    23,860
    +3,078
    Well I emailed Revo support and asked them about streaming from the iPad to the AXiS to the iPad and this is the reply I got....
  7. Azzin
    Nov 5, 2005
    23,860
    +3,078
    Well I'm on the phone to Apple now and they have just told me the iPad doesn't support streaming.
    I then asked why it said it did on the AXiS's webpage and I'm now on hold while she has gone to "check with a senior tech"...
