New APS-C Compact from Sony?
Discussion in 'Digital Photography' started by eddiewood, Feb 21, 2012.
  1. shotokan101
    shotokan101 Well-Known Member
    Jun 16, 2009
    56,755
    Media:
    5
    Albums:
    4
    +13,275
    Err - wasn't particularly thinking about it - you seen one on TP ?
    BTW - managed to prove to myself that it's my technique that's the problem with the siggie F4 :facepalm:
    [​IMG]
    Also - what I meant was that I'd be happy with better third party support for E-Mount ;)
    JIm
  2. Johnmcl7
    Johnmcl7 Active Member
    Jul 8, 2005
    2,413
    +472
    I can't see any non-technical reason why Sony wouldn't produce pancake lenses, it's the real achilles heal of the system and seems to be the trade-off from their very small bodies. Sigma's two attempts at producing compact lenses for E-mount are pretty terrible as the lenses are bulky and slow.
    John
  3. eddiewood
    eddiewood Active Member
    Dec 11, 2007
    6,535
    +983
    lol!
  4. twist
    twist Active Member
    Nov 19, 2006
    10,373
    +1,490
    Dont think anyone in their right mind would spend 11k on that lens in the first place when you can get an alt for far less. And then sell it for a huge loss even if they were that stupid.
    Is that a crop Jim?
  5. godsakes
    godsakes Member
    Dec 3, 2007
    1,550
    +223
    I tend to agree, it's more of a marketing tool for sony than anything else i.e. the equivalent of nations having nuclear weapons to say they're in the big boys club. There might more scope for it in the future if sony releases more sport orientated FF bodies.
  6. eddiewood
    Dec 11, 2007
    6,535
    +983
    Except the development time for a nuclear weapon is shorter. :D
  7. godsakes
    godsakes Member
    Dec 3, 2007
    1,550
    +223
    +1 :rotfl:
  8. shotokan101
    Jun 16, 2009
    56,755
    Media:
    5
    Albums:
    4
    +13,275
    Yes - 100% crop - pretty much straight from camera and cropped in LR - idea was to compare with the 70-300mm G TBH but "operator error" put paid to that :facepalm::blush:
  9. twist
    twist Active Member
    Nov 19, 2006
    10,373
    +1,490
    Looks good for a 100% crop mate.
    • Thanks Thanks x 1
  10. shotokan101
    Jun 16, 2009
    56,755
    Media:
    5
    Albums:
    4
    +13,275
    Thanks - I thought so too - the 70-300 shots just didn't compare - but the again they were all shot handheld at 1/25th :blush: :suicide:
  11. twist
    twist Active Member
    Nov 19, 2006
    10,373
    +1,490
    Jim Jim Jim, how many times, shutter speed needs to generally be equal to focal length when handheld, with Sonys IS a bit lower.
  12. shotokan101
    Jun 16, 2009
    56,755
    Media:
    5
    Albums:
    4
    +13,275
    LOL - I know that - you obviously missed the "opeator error" part :D
    ...I had previously been shooting some pet shots in low light with the 17-70 using auto ISO and 1/25th sec in shutter priority and didn't notice I had knocked the dial back to shutter priority when I changed the lenses over :blush:
  13. topgazza
    topgazza Active Member
    Sep 3, 2006
    11,257
    +1,608
    Humour me ....I've read this many times. Practical examples for my simple mind please :facepalm:
  14. twist
    twist Active Member
    Nov 19, 2006
    10,373
    +1,490
    In the viewfinder youll see 1/???, thats your shutter speed. If you have a 300mm lens set at 300mm your shutter speed should be about 1/320, if its set at 200mm it should be 1/200, this gives a pretty good shutter speed for handholding, using a tripod you can go lower.
    • Thanks Thanks x 1
  15. topgazza
    Sep 3, 2006
    11,257
    +1,608
    In my viewfinder I see the woman next door in the shower......
  16. Johnmcl7
    Jul 8, 2005
    2,413
    +472
    Just a small addition to this, you need to go by equivalent focal length so the above all applies on a full frame camera but for a crop camera you would need to go by 1 over the equivalent focal length. It's only a rough rule though particularly with any form of stabilisation which depending on how effective it is can drop a few stops below.
    John
    • Thanks Thanks x 1
  17. topgazza
    Sep 3, 2006
    11,257
    +1,608
    How do you mean "1 over the equiv focal length" John ? I'll have a play around anyway...so thanks guys. Always a place to learn things.
    Anyway, she's pulled the blind down..... its a tough game this photography lark
  18. twist
    twist Active Member
    Nov 19, 2006
    10,373
    +1,490
    Good mention John. Basically, 1 thumb click past 1/300 for 300mm. So 160mm isnt 1/160 its 1/200.
  19. Johnmcl7
    Jul 8, 2005
    2,413
    +472
    The 35mm equivalent view so if you have a 300mm lens on the A580, the equivalent focal length is 480mm so without IS you're aiming for around 1/500 shutter speed. The reason for this is that you're really going by the field of view rather than the focal length, a very wide field of view such as on an ultrawide lens is only going to need a relatively low shutter speed as the it will be easy to keep the view stable whereas a very narrow field of view on a super telephoto lens is going to need a very high shutter speed as there's going to be a lot of movement when trying to hold the camera steady.
    So if you think 50mm on a full frame camera is then quite a bit narrower on APS-C at around 80mm equivalent, on micro 4/3 or 4/3 is going to be narrower yet at 100mm and on a compact camera with a very small sensor it's going to be a decent telephoto length and need a much higher shutter speed. However as lenses are rarely specified by their field of view it's clearly simpler to use the focal length and then adjust it to the equivalent focal length for sensors smaller than 35mm.
    Most auto-iso or auto-exposures will attempt to maintain one over the (equivalent) focal length so while it's only a rough indicator it generally works reasonably well in practice.
    I do find it difficult changing between cameras with IS onboard and those without, with the Olympus cameras I got very used to the slower shutter speeds I could get away with thanks to the onboard IS so when I initially switched to the Panasonic micro 4/3 and Nikon F mount which don't offer IS in every lens I initially had quite a few blurry photos until I readjusted in my head the right shutter speeds to be using.
    John
  20. topgazza
    Sep 3, 2006
    11,257
    +1,608
    Get it...:thumbsup:
    ...as I said...a place to come and learn. Appreciate this sort of advice as its in plain English. I might never buy a camera magazine again :thumbsup:
  21. shotokan101
    Jun 16, 2009
    56,755
    Media:
    5
    Albums:
    4
    +13,275
    yeah - just take Twists example and multiply your lens focal length by the crop factor - usually about 1.5 :)
    • Thanks Thanks x 1
  22. eddiewood
    Dec 11, 2007
    6,535
    +983
    Or just shoot with the highest shutter speed you can. :rotfl:
  23. topgazza
    Sep 3, 2006
    11,257
    +1,608
    Theres always one who wants to take a shortcut....which is usually me to be fair :eek:
    I would normally do that especially as my 16-105 doesn't have IS so I'll be using the A580's inbuilt IS. Light permitting I would instictrivly use a fast shutter speed. But I'm always game to try things as it may just help me learn a bit more about how things work a bit more and where they came from. Also what I can and can't do with these devices.....
