New APS-C Compact from Sony?
Discussion in 'Digital Photography' started by eddiewood, Feb 21, 2012.
  1. eddiewood
    eddiewood Active Member
    Dec 11, 2007
    6,279
    +830
    Sonyalpharumors have a rumour that Sony are doing a new compact camera with APS-C sensor.
    Linky
    • Thanks Thanks x 1
  2. twist
    twist Active Member
    Nov 19, 2006
    9,737
    +1,246
    I think they should bring out loads more cameras and less lenses.
  3. eddiewood
    Dec 11, 2007
    6,279
    +830
    You should work for Sony, you'd fit right it. :D
  4. shotokan101
    shotokan101 Well-Known Member
    Jun 16, 2009
    54,637
    +12,307
    First think he'd do is change the Badge :D
  5. shotokan101
    Jun 16, 2009
    54,637
    +12,307
    ..they're doing it to bring out some that are compatible with Sigma lenses :devil:
  6. godsakes
    godsakes Member
    Dec 3, 2007
    1,517
    +217
    the interesting thing is the mention of a zoom pancake lens... quite why sony felt the need to stick a body to it instead of a e-mount is well sony i suppose
  7. eddiewood
    Dec 11, 2007
    6,279
    +830
    Well it would certainly sell more cameras... :D
  8. eddiewood
    Dec 11, 2007
    6,279
    +830
    That's the bit that puzzles me. But isn't the "problem" with NEX and pancakes to do with flange distance or someint? Don't ask me, I just read it once and it hurts my head. :p
  9. twist
    twist Active Member
    Nov 19, 2006
    9,737
    +1,246
    Dirty git.
  10. eddiewood
    Dec 11, 2007
    6,279
    +830
    I love the smell of flange in the morning.
  11. shotokan101
    Jun 16, 2009
    54,637
    +12,307
    'cos it's a rebadged Fuji :devil:
  12. godsakes
    godsakes Member
    Dec 3, 2007
    1,517
    +217
    if that were the case for NEX and presumably it not a problem for the likes of samsung NX and m34 etc then all that's stopping sony is adding a few mm to their lenses (like you would with a lens adapter).
    Not sure but I suspect the problem is sony being morons rather than actual technical limitations
  13. eddiewood
    Dec 11, 2007
    6,279
    +830
    It might turn out to be pretty good then. :rotfl:
  14. eddiewood
    Dec 11, 2007
    6,279
    +830
    That'll be the problem, they'll not be able to make a 30mm (or whatever) pancake without making it too long/large. It isn't then a compact pancake and rather defeats the whole point of it. :D
    So NEX offers the advantage of putting practically any lens on the front, but not if you want compactness. Maybe this compact will be Sony's answer to that problem?
  15. godsakes
    godsakes Member
    Dec 3, 2007
    1,517
    +217
    well if was a pancake for a SLR yes, but not for a mirrorless system like samsung. I can assure you the samsung combo with it's 30mm pancake is pretty compact. In any case I'm confident there's no technical limitation just stupidity or deafness on sony's part
  16. shotokan101
    Jun 16, 2009
    54,637
    +12,307
    +1 :mad:
  17. twist
    twist Active Member
    Nov 19, 2006
    9,737
    +1,246
    Who said that.
  18. eddiewood
    Dec 11, 2007
    6,279
    +830
    But we aren't talking about Samsung. :confused:
  19. twist
    twist Active Member
    Nov 19, 2006
    9,737
    +1,246
    Don they make Tellys?
  20. eddiewood
    Dec 11, 2007
    6,279
    +830
    No, they make the panels inside Sony tellys. :D
  21. shotokan101
    Jun 16, 2009
    54,637
    +12,307
    Yeah Sony do that :thumbsup:
  22. eddiewood
    Dec 11, 2007
    6,279
    +830
    Have to say, they make a good ebook reader though.
  23. godsakes
    godsakes Member
    Dec 3, 2007
    1,517
    +217
    let me start again
    sony NEX has a 18mm flange - supposedly this makes it hard or impossible to make pancakes for it
    micro 4/3 has a flange of 20mm and samsung NX has a 25.5mm flange - yet they have pancake lenses - if it was just about flange distance then all we're talking about is adding 2-7.5mm to a pancake lens to make it work on NEX.
  24. twist
    twist Active Member
    Nov 19, 2006
    9,737
    +1,246
    ..... should be making more lenses instead.
  25. shotokan101
    Jun 16, 2009
    54,637
    +12,307
    ....other than for E-Mount I'd probably disagree ;)
  26. eddiewood
    Dec 11, 2007
    6,279
    +830
    So if the Samsung 30mm pancake is 21.5mm long, the Sony version would be getting on for 30mm? Bit chunky.
  27. godsakes
    godsakes Member
    Dec 3, 2007
    1,517
    +217
    well still a huge improvement on the kit lens but as i say it's probably not the actual reason why sony hasn't been releasing pancake lenses
  28. eddiewood
    Dec 11, 2007
    6,279
    +830
    Are you suggesting Sony are crap at getting lenses out the door? How dare you! :rotfl:
  29. shotokan101
    Jun 16, 2009
    54,637
    +12,307
    ...he's not suggesting anything Eddie :D
  30. twist
    twist Active Member
    Nov 19, 2006
    9,737
    +1,246
    ..... for your requirements. You getting the 500 f4?
