Network ID & Transport stream 0000
Discussion in 'Satellite TV' started by DaveHope, Jul 2, 2007.
  1. DaveHope
    DaveHope Member
    Jul 2, 2007
    176
    +25
    Hello all,
    Got myself a freesat box, dish and card yesterday and hooked it all up ok but am having a weird problem actually getting any signal.
    When going to the signal test option Signal and quality hover around the 60% mark, lock indicator says "OK" but network ID and transport stream stay with 0000. When going to browse channels I get an error about there being no signal.
    Box is a Panasonic DSB40.
    Things i've tried:
    - Manually updating to the latest firmware (hold backup bottom thing)
    - Going through the "New Installation" procedure (401select)
    Any ideas as to what the cause could be? - the fact that "lock indicator" says OK, and network and transport Id remain with 0000s seems a bit strange.
    Cheers!
  2. Fugitivewolf6
    Fugitivewolf6 Guest
    check the connections from the dish.. sounds like a stray wire from the outer braid touching the inner core...
  3. DaveHope
    DaveHope Member
    Jul 2, 2007
    176
    +25
    Thanks. Will take a look as soon as I get in thisevening.
  4. Chris Muriel
    Chris Muriel Active Member
    Jun 14, 2002
    6,816
    +696
    Surely a stray wire shorting would result in no signal and no lock (as well
    as the 14/18 volts being shorted which wouldn't be a good thing).
    Chris Muriel, Manchester
  5. davemurgatroyd2
    davemurgatroyd2 Active Member
    Dec 26, 2004
    7,104
    +1,091
  6. DaveHope
    DaveHope Member
    Jul 2, 2007
    176
    +25
    Yep, installing myself. Refuse to pay an engineer for what's essentially 10mins work :)
    Hrm, ok. Will see if I can align it to 28.2 east then, thanks!
  7. Fugitivewolf6
    Fugitivewolf6 Guest
    may be wrong... but you shouldnt get any quality reading unless ur hooked up to the right bird... may show strength but not quality... and yes ive had a problem with 0000 before... changed everything.. and it turned out to be a singal strand of outer braid... weird yes.. but after fixing that.. no problems with the old gear...
  8. davemurgatroyd2
    Dec 26, 2004
    7,104
    +1,091
    No I've had both signal strength and quality readings on 19.2 previously when a dodgibox is aligned on 19.2 - there is a transponder on 19.2 with same freq and symbol rate as the Sky dodgibox default.
  9. DaveHope
    DaveHope Member
    Jul 2, 2007
    176
    +25
    Hrm. Thanks for the ideas all.
    I've checked all connections, replaced the one which connects to the DigiBox and still no luck. Same problem.
    Interestingly, wherever I point the dish I get the same results (unless I point it directly at the floor, when I get nothing). Sat on the floor facing the house opposite gets me a lock. Is that normal? - Should it really connect just that easily, moving the dish through 360degrees doesn't drop the lock, weird?
  10. SamRadford
    SamRadford Member
    Jul 12, 2005
    3,965
    103
    +366
  11. DaveHope
    DaveHope Member
    Jul 2, 2007
    176
    +25
    SamRadford, hadn't seen the movie. Have not watched it. No matter where the dish is aligned I get 0000s and an "OK" lock indicator.
    Called Sky and asked them. They suggested it was a problem with the LNB and said I should call an engineer. Not believing what they said I tried my box on another (very old) dish that was on the house when we bought it, same problem.
    So, I'll be borrowing a friends box tonight to see if the box is the cause of the problem.
  12. SamRadford
    SamRadford Member
    Jul 12, 2005
    3,965
    103
    +366
    So lemme get this straight: you are trying to get a signal without aligning the dish with a meter? Sky Digiboxes are easily confused. In my experience, once that "lock" indication appears, you won't get rid of it till you reboot the Digibox. Does it work with a friend's dish?
