netgear DG834GT Cant update firmware
Discussion in 'ISPs & The Internet' started by jonnyv, Dec 30, 2008.
  1. jonnyv
    jonnyv Member
    Mar 31, 2002
    1,979
    48
    +25
    Im having problems downloading updated firmware from the netgear site.
    Can anyone else download the latest firmware for the DG834GT ?
    thanks
  2. ItShMe
    ItShMe Member
    Aug 4, 2005
    20
    3
    +7
    Downloads fine from here, using the right click and save or left click then either opening in ZIP or rar. 3.30mb file.
    What error are you getting? Does the file start to save? Does it have a zip association when downloaded?
    If you can download it then unzip then login to your router. Select Maintenance, click Router Upgrade, locate unzipped file.
    Are you able to browse the net fine? If not then maybe a ISP/DNS issue?
  3. jonnyv
    jonnyv Member
    Mar 31, 2002
    1,979
    48
    +25
    Thanks for the reply
    I right click on the file and select save,but it opens a new window and doesnt download, 'a connection with the server cannot be established' is the error message.
    Any chance you could email me the file?
  4. ItShMe
    ItShMe Member
    Aug 4, 2005
    20
    3
    +7
    Sent
    • Thanks Thanks x 1
  5. xrayvisionguy
    xrayvisionguy Guest
    Hi everyone
    I am having problem upgrading my netgear dg834gt router. It had sky firmware installed- i used to use sky broadband - now i am using a different provider. I tried to upgrade using netgear dg834 gt original firmware v1.02.16. I have connected my laptop with cable to the router and used the recovery utility which didnt work - now i think i held the reset button for long timei have green and amber light fashing - i have tried using recovery tool again - nothing works. now i dont have anythng not old firmware or the new the one -router isnt working. when i start router i have those two lights flashing. what can i do to solve this.
    And my OS is xp home sp3 - \i also use vista.
  6. jonnyv
    jonnyv Member
    Mar 31, 2002
    1,979
    48
    +25
    Are you able to access the router setup screen by typing http://192.168.0.1
    into your internet browser ?
  7. xrayvisionguy
    xrayvisionguy Guest
    no i can't
  8. beerhunter
    beerhunter Active Member
    Nov 9, 2005
    6,335
    +759
    It sounds like your router is toast. This is the very reason why upgrading for no discernible reason is counseled against. That was not the situation in this case of course.
  9. leeboy1411
    leeboy1411 Member
    Apr 10, 2007
    112
    +5
    Yep defo toast netgear router, same happened to mine, they can go at any time.
    Liam
  10. beerhunter
    Nov 9, 2005
    6,335
    +759
    I don't agree with that last statement. I have found Netgears to be extremely reliable. It is only when people fiddle around with them that problems arise.
  11. leeboy1411
    leeboy1411 Member
    Apr 10, 2007
    112
    +5
    Im not saying that Netgear routers are unreliable.I have always used Netgear, all Iam saying that yes routers can fail suddenly over a period of time. According to one of his statements below he can't use the web base configurator ( http://192.168.0.1) I would recommend trying to insert a pin into the reset button on the back of the unit. If this does not work then its definately time to go router shopping. Do you switch the router off every night? as this is one of the major causes of router failure, when you switch it off it is like a shock to the system thus causing the firmware to fail.
  12. jerryq7777
    jerryq7777 Active Member
    Sep 28, 2004
    3,527
    +394
  13. leeboy1411
    leeboy1411 Member
    Apr 10, 2007
    112
    +5
    Like I said before he cannot log in therefore cannot access the firmware or use the recovery feature, if you cannot log in at all and/or the orange light conitunes to blink then the router is definately faulty, there is not much more you can do.
