Netgear DG834G Router Replacement Antenna??
Discussion in 'Networking & NAS' started by lowercase, Dec 3, 2009.
  1. lowercase
    lowercase Member
    Mar 19, 2009
    128
    The antenna on my Netgear DG834G V2 router has broken, on this version the antenna is removable by unscrewing it,, can anyone recommend a replacement, if that's possible?
  2. Mark Grant
    Mark Grant Member
    Oct 27, 2000
    1,357
    63
    +177
  3. lowercase
    lowercase Member
    Mar 19, 2009
    128
    Thanks for those links, the router is downstairs in the kitchen and the PC is upstairs, but not above the kitchen lol When it worked, the PC picked up the router signal ok, despite its location.
    Which of these would you recommend?
  4. Mark Grant
    Mark Grant Member
    Oct 27, 2000
    1,357
    63
    +177
    I would go for the 5db, higher gain such as 7 or 9 has longer range on the same floor but might not have enough coverage upstairs.
    the standard antenna is about 2db so even 5db is much better :)
    Mark.
  5. lowercase
    lowercase Member
    Mar 19, 2009
    128
    Thanks :thumbsup:
    ordered the 5db one, lets hope it works lol
