Netflix Onkyo 509 streaming from pc
Discussion in 'Streamers & Network Media Players' started by ewizzy, Dec 9, 2012.
  1. ewizzy
    ewizzy Active Member
    Feb 24, 2012
    1,179
    +254
    Hi there,
    I didnt know which section this should be in so please feel free to move to a more appropriate section.
    I have just signed up for netflix for streaming movies and tv shows. I'm streaming from the netflix site on my PC, sound is from an optical out on the PC to the Onkyo 509 - Video is VG to PC. 5.1 works perfectly for any files through media player and VLC but not from netflix.
    I contacted the help chat thing on Netflix and they told me that 5.1 isnt streamed from PC, I have found lots of sites and other people that say it is possible though. :confused:
    Any ideas?
  2. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,621
    +816
    Def. media not music!
  3. ewizzy
    Feb 24, 2012
    1,179
    +254
    Yes, definitely media
  4. next010
    next010 Active Member
    May 29, 2005
    8,838
    +1,729
    Well a quick Google says it cant be done & Netflix don't support it on PC's so not sure where you read that it can.
    You might want to consider a WDTV Live media player (around £65) which will play most of the stuff VLC can play and also supports Netflix with 5.1 audio support.
    If you want to stream the video files easily from the PC to the WDTV, use Serviio which is free.
  5. ewizzy
    Feb 24, 2012
    1,179
    +254
    I've installed it on my Xbox which also outputs in 5.1
