NAD Soft Clipping
Discussion in 'Integrated Amplifiers & Receivers' started by Douzeper, Mar 8, 2005.
  1. Douzeper
    Douzeper Member
    Aug 22, 2004
    190
    16
    For those with a NAD amp, do you leave the soft clipping on or off? does it make any difference to sound at low levels or just clips when up high?
  2. Andywilliams
    Andywilliams Member
    Sep 27, 2002
    2,052
    +64
    Nad do say to run with soft clipping off as it can effect dynamics.If your going to be having a party or whatever it would be wise just to flick the soft clipping switch on as some so called mates arnt too careful with the volume knob and you dont want your tweeters frying.
    Cheers Gonzo.
    Ps used to own a nad t752. :)
  3. Douzeper
    Douzeper Member
    Aug 22, 2004
    190
    16
    Ahh cheers for that -must go turn it off!
