My system, nearly done :D
Discussion in 'Members' Home Cinema Gallery' started by EddThompson, Aug 4, 2006.
  1. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    well after 3 years my home cinema is nearly done, just my cabinet to finish (put the doors and shelves in, yes i made it meself, so no mockery) and the odd cable to find a home for.
    On to the pictures:
    [​IMG]
    These are my sofas, mmmm comfy :D
    [​IMG]
    My Dvds, you can also see the projector.
    [​IMG]
    screen up.
    [​IMG]
    screen down, you can also see the old sub to the right, the big black box, peaking round the end of the sofa.
    [​IMG]
    The new sub, a bk monolith passive.
    [​IMG]
    and for size comparison with my 18 month old son, tho hes quite tall apperently :D
    [​IMG]
    the stuffs, On the left we have:
    Denon AVC1-SE
    Denon 3900
    3 Beheringer euro power 1500s, 4500 watts :D :D
    On the right:
    Behringer Feedback destroyer
    Motorised dish box and xbox HD DVD
    Xbox 360
    PS3
    Sky plus 160
    Pioneer Laserdisc player
    And on the top sits my lp player, a bix with a rega rb300 arm modified by origami audio
    Speakers are the orginal b&w thx system.
    Projector is an h79
    Im well :D:D:D:D:D first time its ever looks tidy!!
    edd
    Big edit, the cabinet photo has been updated and some photos of them monolith. See the 2nd page for some screen shots!
  2. neil666
    neil666 New Member
    Jun 30, 2006
    375
    +13
    Looks good:thumbsup:
    That sub is Huge!! :) :)
    You got a lot of dvds, have you got your collection down on profiler?
  3. rhino2k
    rhino2k Member
    Oct 20, 2005
    2,329
    63
    +149
    crikey, that amp is HUGE :eek: and the extra power is just being greedy......
    bet your neighbours love you :devil:
    looks good though :thumbsup:
  4. CFS
    CFS Member
    Dec 2, 2005
    493
    +58
    Nice looking setup, very professional. Might you wish to add some shelves to your unit to prevent strain and overheating on the components though?
  5. UnicronI
    UnicronI Guest
    what are 'Beheringer euro power 1500s, 4500 watts'?
  6. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    Its standard 19" racking, its just a matter of ordering or making the shelves, just not got round to it, the main power amps are designed to be stacked and have front to back air flow, not even any vents on the top. The denon has plenty of room too, so its ok for now.
    Edd
  7. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    They are stero power amps, of which i have 3.
    into 2 ohms they produce 750 watts a channel (well, supposedly) so that gives a total of 4500 watts :).
    Since the front speakers are 4 ohm, and the rears 8 ohm, its more like 380 watts for each front and cente, and 240 for each rear, still bonkers amounts of power.
    edd
  8. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    No, something i have though of doing, but i imagine to be a mamoth task!
    as a guess, i have 500 or so dvds.
    Sub is big, but not so good. getting long in the tooth. but it works so ill keep it, the set actually came with 2 subs, the other one "popped". luckily, i have no neighbours :D
    Thanks for the interest all.
    edd
  9. Logitek
    Logitek Guest
    Sick setup:thumbsup:
    What 360 games you have?
  10. Rogers
    Rogers Member
    Nov 3, 2004
    165
    28
    +26
    Love the massive collection of DVDs and that mammoth AVR!!! Great stuff!!!
    Well done, its an awesome cinema you have there!!:thumbsup:
  11. John 1987
    John 1987 Member
    May 25, 2005
    1,136
    +176
    Lovely set-up, those sofas do indeed look comfy. :thumbsup:
  12. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    A small update, the cabinet now looks like this :
    [​IMG]
    pretty good if you ask me, you can see how i made it in the thread ive just posted in the DIY section.
    Behind the cabinet:
    [​IMG]
    That was for you cable fetishists out there :rotfl: , I tell you, that took some time.
    edd
  13. tipple
    tipple Member
    Aug 14, 2005
    35
    Edd,
    I downloaded DVD profiler from this link http://www.intervocative.com/Downloads.aspx to catalogue my collection. All you need to do is input the bar code data and it downloads the DVD data automatically. I suppose other programmes work the same way. For the sake of 5 nights work (100 per night @ 1 hr) it would be worth it.
    Great setup by the way.
    • Thanks Thanks x 1
  14. Nimby
    Nimby Active Member
    Jan 27, 2004
    9,162
    +689
    Very nice Edd! :smashin:
    Regards
    Nimby
  15. ajcasey
    ajcasey Member
    Feb 19, 2006
    286
    28
    +27
    I've got that amp in black,wouldnt sell it for a gold pig.Very nice room really tastefull(that didnt sound gay did it:D )
  16. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    the gold is hideous isnt it,but i buy all my gear used, and as far as i know color doesnt affect the sound:D , luckily, i dont have to look at it much :rotfl:
    edd
    edit, think i misread that :D i thought you called my amp a gold pig lol, ahhh its been a long day.
  17. Sniper
    Sniper Member
    Apr 27, 2004
    1,293
    +88
    Are the fans on the EP1500s ok? I mean are they too loud? Did you change them? And how would you rate them (the amps not the fans!) - what would you compare them to?
  18. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    the fans were like a small jet aircraft taking off. i swaped them for papst silent fans, cant realy hear them over the projector now.
    for the money i think pro amps are great, they are very heavy mind (15kg each) and 19" wide. Much better sound quallity than i had imagined, and so much power in reserve its just not an issue. if you have the room, dont mind swapping the fan, give one a try, £170 i payed for each amp, if you dont like it, sell it on ebay :D
    edd
  19. j0hn
    j0hn New Member
    May 26, 2005
    1,944
    +74
    or send it back :smashin:
    http://www.dv247.com/page/Help#
    Digital Village are particularly concerned with your complete satisfaction. Therefore in addition to these regulations, if within 14 days of purchase, the consumer wishes to return goods to us for reasons of incompatibility or they are not satisfied with the goods, subject to the previous exclusions, Digital Village will refund the consumer provided the goods are returned to us in an undamaged and saleable condition. The consumer is under a duty to restore goods to us and to maintain them in the condition in which they were supplied by us. If goods are damaged or not saleable as new, Digital Village reserves the right to seek recompense.
  20. Dynaudio Desire
    Dynaudio Desire Member
    Dec 8, 2005
    1,293
    +63
    What subwoofer do you have Edd?
    Lovely looking setup!! And some very nice kit.
  21. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    the subwoofer was the b&w one from the thx system. It was ok, went loud but thats about it, a very bloated over warm sound.
    So now i have a monolith, still passive, bk made one for me, i havnt updated the pictures due to illness, ill get round to it soon.
    edd
  22. Sniper
    Sniper Member
    Apr 27, 2004
    1,293
    +88
    I'll eventually give pro-amps a try, they're too tempting to just ignore - I actually live right next to a pro-audio shop. They have Behringer, Mackie, Lexicon (!!) and other brands available (I think Crown too).
    All the best for the illness you mentioned.
  23. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    ahh nothing too bad, bad back, throw in an inner ear infection (paiin fulll) and a 17 month old baby, tasks like taking a photo of the subwoofer go out thw window.
    I always intened the behringers as a stop gap to getting some rather serious crowns or something similar, but ive been so happy with the sound i doubt ill bother.
    edd
  24. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    I have finaly updated the first post, enjoy.
    edd
  25. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    some screen shots:
    T2 bluray:
    [​IMG]
    [​IMG]
    Talladegga nights bluray:
    [​IMG]
    [​IMG]
    Grand prix hd-dvd:
    [​IMG]
    [​IMG]
    [​IMG]
  26. AngelEyes
    AngelEyes Active Member
    Mar 23, 2004
    9,839
    +1,217
    You HD whore:D
  27. Spooksta
    Spooksta Member
    Nov 7, 2000
    2,112
    +94
    You can plug the 360 wireless adapter into the HD-DVD add on you know :):thumbsup:
  28. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    It kept cutting out when plugged into the hd-dvd, i think its a probelm with my router actually, but i plugged it in the front to make sure.
    edd
  29. Mac User
    Mac User Active Member
    Sep 27, 2006
    4,154
    +288
    Ha, whats this HD-DVD like.. I was going to buy this film but have read a review that this movie is not that good in HD.. whats the transfer like ?
  30. EddThompson
    EddThompson Member
    Feb 28, 2005
    409
    +23
    If you like the movie, the hd-dvd is fantastic, transfer is amazing, puts a lot of modern movies to shame.
    edd
