Moving from ipad/ios to an android tab
Discussion in 'Tablets' started by emporer, Jun 30, 2013.
  1. emporer
    emporer Well-Known Member
    Mar 10, 2005
    8,082
    +1,622
    I currently have an ipad 3, love the retina display, its jailbroke mainly for xbmc which I use daily, I'd like to move to an android tablet so I can use sky go and retain stuff like xbmc as I wouldn't need to root it. I was looking at something like the Nexus 10 for its resolution etc, does xbmc run just as well on the nexus with android? I mainly watch 1080p x264 stuff on xbmc on my ipad and its flawless, would the nexus handle them as good?
    I have xbmc on my galaxy s4 and with xbmc on that it struggles with 1080p x264 stuff and is not smooth, I just need good playback of this stuff and the ability to use sky go which is a no go for my jailbroken ipad.
  2. xmb
    xmb Member
    Sep 29, 2004
    657
    +75
    Save yourself some money and restore your iPad to original then use Plex in place of XBMC and load Shy Go. Job done!
  3. Boostrail
    Boostrail Active Member
    Nov 27, 2007
    5,122
    103
    +389
    Why?? "retina" s only a resolution standard that others also meet - it says nothing else about the display which is fairly run of the mill Samsung technology.
  4. Boostrail
    Nov 27, 2007
    5,122
    103
    +389
    Am I correct - you want a player for 1080p X264? Is VLC not available on iOS? Or do you want to stream to a TV or other device?
    I have tried using XBMC on Android and gave up.
    On yor S4 you can use multitudinous players inc VLC. For streaming / multisharing your S4 should have Miracast built in!
    Or am I missing something in your requirements???? If so please explain.
