Moving files from PS3 to PC
Discussion in 'PS3 Forum' started by Axum, Mar 5, 2008.
  1. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    OK, we all know PC > PS3 is easy.
    How do i go about taking files off my PS3 HDD ? I've copied across some HD films, but I want to upgrade my PS3's HDD and i don't have the original HD sources anymore.
    As they are bigger than 4GB i will presume that i cannot do a normal backup of the PS3 to an external HDD.
    So is there any way i can copy from the PS3 back to my PC whilst i upgrade the internals ?
  2. Phunky
    Phunky Member
    Jul 18, 2007
    1,898
    +146
    Take the HDD out and plug it into your PC via SATA?
    Im guessing you should be able to see it just like any other drive, unless they have some strange encryption going on the drive.
  3. psikey
    psikey Active Member
    Oct 5, 2005
    6,498
    +697
    Doesn't work.
    The PS3 uses a file format that the PC doesn't recognise (unless you have some special software I suppose).
    Even Partition Magic 8 couldn't see the format of a drive removed from the PS3 & put in a USB2 SATA housing.
  4. Phunky
    Phunky Member
    Jul 18, 2007
    1,898
    +146
    I thought the PS3 just used FAT32 - guess not then im sure someone will come up with a little tool soon enough that will read it for us ;)
    Guess for now the only way is via the Media Backup?
  5. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    No it can't use FAT32 as it accepts files larger than 4GB.
    I can't do anything with the drive itself as i have a really old pc and it doesn't support SATA.
    Looks like i'm stuck and will have to actually watch the films then delete, not too much of a hassle!
  6. psikey
    Oct 5, 2005
    6,498
    +697
    Are the files larger than 4GB? If not, why not just copy them to a USB hard drive or stick?
    Stike that :rolleyes: I just re-read your post.
  7. psikey
    Oct 5, 2005
    6,498
    +697
    Can't you use a web-based upload tool from the PS3 browser? Just a thought, not tried myself.
  8. psikey
    Oct 5, 2005
    6,498
    +697
  9. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    That's an interesting option. I can't see it working though if a PC can't even "see" the PS3 HDD over a network.
    Also, and i'm sure most people are the same, it would take AGES to upload a 10GB file as mostly all ISP's offer paltry upload speeds.
  10. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
  11. psikey
    Oct 5, 2005
    6,498
    +697
    I'm out of options then :thumbsdow
  12. Mildoo
    Mildoo Member
    Oct 17, 2007
    324
    +29
    i in the same boat as well, very annoying.
    I have looked everywere for a solution for this, but no luck yet :(
  13. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    To be honest i don't think there is a solution. I can't see how there would be seeing as the PS3 HDD is unreadable in it's current state.
    Oh well, i'll just have to remember not to copy any more HD movies onto it for the time being!
