MMS "Unable to Send" on HTC Radar
Discussion in 'Windows Phone' started by goatman, Feb 7, 2012.
  1. goatman
    goatman Member
    Mar 11, 2006
    198
    +7
    Apologies if this has been asked elsewhere . . .
    I have an HTC Radar on Tesco Mobile. Tesco can't help with this, and neither can HTC.
    I can't send MMS messages. When I try, I get "unable to send".
    Is there a setting I should change somewhere?
    Thanks!
    - Mike
  2. bagg3rs
    bagg3rs Member
    Dec 17, 2005
    341
    28
    +55
    Have a look for the HTC connection app
    HTC Radar How-tos - Data connection
    Using Connection Setup
    The Connection Setup app makes it quick and easy to reconfigure your data connection settings.
    When you change to another SIM card and restart your phone, Connection Setup opens and sets up your phone's data connection automatically based on your new SIM card.
    If your mobile operator uses different profiles of connection settings for their data services (for example, different settings for Internet and WAP), you can also use this app to easily switch between their profiles.
    Important: This app is preinstalled in most phones. If you don't see it on your phone, open the HTC Hub and download this free app.
    Switching to another data connection profile
    Manually choose a data connection profile in Connection Setup, if the app did not auto configure your phone's data connection, or if you need to switch to another profile of your mobile operator so you can use a certain data service.
    On the Start screen, tap .
    Tap Connection Setup.
    You can:
    Switch to another data connection profile of your mobile operator
    Tap the Carrier field.
    Select the profile you want to use.
    Change to another country and mobile operator
    Tap > manual select.
    Select the country and mobile operator to use.
    Tap to apply the changes.
  3. goatman
    goatman Member
    Mar 11, 2006
    198
    +7
    Thanks, bagg3rs.
    I searched Connections Setup and found the App, although it didn't appear in the Apps list - I've sent an MMS message and it hasn't produced an error!
    Much appreciated.
