mkv2vob issue (tsmuxer.exe has stopped working)
Discussion in 'PS3 Media & Streaming' started by houly, Aug 9, 2010.
  1. Clippy
    Clippy Member
    Jan 18, 2005
    49
    +3
    Thanks for this. Been having issues for a couple of months and came here to post for help. An easy fix is what we like.
  2. colt556
    colt556 Member
    Oct 25, 2010
  3. lolitsme
    lolitsme Member
    Oct 26, 2010
    I keep running into this error on one particular file -
    I followed all instructions properly so not sure what is going on here.
  4. easyrider
    easyrider Member
    Nov 9, 2008
    2,153
    +114
    :thumbsup:
    • Thanks Thanks x 1
  5. easyrider
    easyrider Member
    Nov 9, 2008
    2,153
    +114
    Does the file play afterwards?
  6. th3sundanc3kid
    th3sundanc3kid Member
    Apr 23, 2009
    2
    4
    I know this is a bit of a bump, but I only just ran in to the problem as I don't use mkv2vob all the time, and found this thread. Just wanted to say thanks, that workaround has saved me from a bit of a headache.
  7. Raiders
    Raiders Member
    Mar 7, 2005
    102
    +4
    The work around not working for me keeps tell me TSmuxer has stopped working :(
  8. arslan0123
    arslan0123 Member
    Dec 26, 2010
    Thanks alot easyrider
    all videos working now:)
    your the best
    had to register to say Thankyou
  9. rkcp
    rkcp Member
    Apr 28, 2010
    35
    thanks Easy rider, that worked for me, was really bugging me
  10. easyrider
    easyrider Member
    Nov 9, 2008
    2,153
    +114
    Give me thanks for real on the left :D
    • Thanks Thanks x 2
  11. SpamJavelin
    SpamJavelin Member
    Mar 28, 2008
    285
    +21
    Big thanks, worked great for me.
  12. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
  13. Alphawao
    Alphawao Member
    Feb 23, 2007
    347
    +26
    Thanks easyrider I has some files that wouldn't cooperate with mkv2vob but this fixed it!
  14. savoy
    savoy Member
    Jan 19, 2009
    7
    4
    After a quick google came upon your remedy for the tsmuxer.exe problem, all working fine now:clap:
  15. Omega
    Omega Member
    Feb 3, 2008
    134
    +13
    It's a problem with TsMuxer, MKVtoolnix since after 4.0.0.0 has included header compression and TsMuxer can't cope with it. It's actually in the MKV specifications so technically it's a bug in TsMuxer. Until an update is released for TsMuxer theres no option but to turn off header compression as explained above or use version 4.0.0.0 or less.
  16. mister9
    mister9 Member
    Mar 8, 2011
    Is everyone really experiencing ~4 minute wait times for muxing of 4 GB mkv files? Mine is taking closer to 40 minutes for a 4.7GB mkv with DTS audio and I'm running it on a core-i7 mid 2010 macbook pro with 8GB RAM :(
  17. easyrider
    easyrider Member
    Nov 9, 2008
    2,153
    +114
    Iv'e stopped using MKV2VOB and now use XBMC...Not a help but I was so mad with the hassle I needed to rethink things
  18. N42
    N42 Member
    Nov 2, 2004
    549
    +20
    I just used it and it worked a charm
  19. clausdk
    clausdk Member
    Sep 18, 2010
    33
    I remux as suggested with "none" selected on all the files.
    The new MKV file still causes the tsmuxer stopped working....argh.
  20. Omega
    Omega Member
    Feb 3, 2008
    134
    +13
    When you open the MKV in MKVtoolnix, what information does it state about the tracks, specifically Video and Audio types?
  21. clausdk
    clausdk Member
    Sep 18, 2010
    33
    V_MPEG4/ISO/AVD
    A_DTS
    A_AC3
    I ended up installling the PS3 mediacenter to play my files.
  22. mikeyp
    mikeyp Active Member
    Sep 30, 2004
    2,081
    +304
  23. jballs
    jballs Member
    Apr 28, 2011
    thanks for the help guys, this issue with mkv2vob has been driving me NUTS. You guys ROCK!!!
  24. ourdave
    ourdave Member
    Dec 27, 2008
    2
    I've re-downloaded loads of stuff to get round this problem and it's been a proper pain in the bum.
    Thanks very much for this - 2 minute job, all sorted, top man!
  25. bleedbreakdowns
    bleedbreakdowns Member
    May 12, 2011
    <--- yet another guy who joined this forum simply to thank you Easyrider. Thank you.
  26. iceplayer929
    iceplayer929 Member
    May 27, 2011
    2
    Eazyrider!!!!!! You are the man! This is a major problem Ive had for like a year! Thank you so much!!!
  27. easyrider
    easyrider Member
    Nov 9, 2008
    2,153
    +114
    No probs guys!:smashin:
  28. Powerslave
    Powerslave Member
    May 28, 2011
    I also registered to thanks for this info.
    This is fixed in later versos of MKV2VOB, but the patching DTS no longer works, in 2.4.9. for sure, so, I went back to 247, and with this info, EVERYTHING works. I was tired of the Cinavia messages, and you don't get it with the DTS audio. I had a movie I put into V249 of MKV2VOB, and had to convert to AC3 as Patching DTS would bail after two bars showed up. I had to use the DTS to AC3 option, and CINAVIA. With V247 of M2V, it worked, and no Cinavia. I just got another movie, and got the ntdll.dll error with 247, and using this info here, it completed.
  29. iceplayer929
    iceplayer929 Member
    May 27, 2011
    2
    Do you know how to solve this?
    Unsupported media type 15 for AVCHD/Blu-ray muxing
    It is a MKV File..
    Please help Easyrider!!!! lol :thumbsup:
  30. themediaman
    themediaman Member
    Nov 17, 2010
    1,914
    +169
    mkv is simply the box that holds the audio and video..........mediainfo can give you more detail to whats inside........
