mkv2vob issue (tsmuxer.exe has stopped working)
Discussion in 'PS3 Media & Streaming' started by houly, Aug 9, 2010.
  1. houly
    houly Member
    Jan 30, 2006
    231
    +5
    anyone had this error whilst about to start converting to vob ?
  2. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    • Thanks Thanks x 12
  3. houly
    houly Member
    Jan 30, 2006
    231
    +5
    just tried that, not really sure what to do with it.
    liked mkv2vob, its basic and easy
  4. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    Just remux the MKV to another MKV
    Highlight the video track choose compression none
    Highlight the audio track choose compression none
    Then hit the remux button takes about 3mins on my 4ghz i7
    Its easy
    Then import the new remuxed MKV into MKV2VOB
    • Thanks Thanks x 4
  5. houly
    houly Member
    Jan 30, 2006
    231
    +5
    ran it with an mkv mate, mkv2vob didnt even open it
  6. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    Did you remux the original MKV in MKVtoolnix?
  7. houly
    houly Member
    Jan 30, 2006
    231
    +5
    yeah sure did mate, took about 4 mins with around 8gb movie
  8. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    Did it error?
    Did you change the options in the extra settings tab for both audio and video to compression none?
    If you didn't then it won't work
  9. houly
    houly Member
    Jan 30, 2006
    231
    +5
    dont know what options your meaning ?
    i did have a new output movie but it didnt even work
    thats why i was preferring to use mkv2vob, as ive not got the best understanding with these programs
  10. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    You use MKV2VOB with the remuxed MKV otherwise MKV2VOB will crash.
    I have just done it with a MKV that crashed MKV2VOB with exactly the same error tsmuxer.exe has stopped working,
    I followed the steps and remuxed in MKVtoolnix and imported the new MKV into MKV2VOB without issue, So I know it works.
  11. houly
    houly Member
    Jan 30, 2006
    231
    +5
    deleted the files now, will download a new one the now, and try it again.
    any idea whats happened with mkv2vob ? and will it be fixed ?
  12. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    [​IMG]
    Make sure you have none selected for both video and audio
    • Thanks Thanks x 8
  13. houly
    houly Member
    Jan 30, 2006
    231
    +5
    ok mate, will give it a bash.
    thanks for the simple terms lol
  14. MrGKaplan
    MrGKaplan Member
    Jan 2, 2007
    69
    +3
    Good workaround easy, working fine here, you the man :smashin:
  15. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    :smashin:
  16. houly
    houly Member
    Jan 30, 2006
    231
    +5
    tried to select none mate, but its not even highlighting to let me select anything...
    any idea why this is ?
  17. houly
    houly Member
    Jan 30, 2006
    231
    +5
    ok bud, tried running it anyway, the three boxes were ticked like the picture before...
    it said it worked on that program.
    opened up mkv2vob and its still saying tsmuxer.exe is not working
    is there any other way to convert my mkv movies to vob for the ps3 ? i feel as if im ******* against the wind
  18. pxr5
    pxr5 Member
    Dec 28, 2005
    649
    +70
    Make sure you have selected the thing you want in the box above before selecting 'none' in the compression drop down of the extras options tab
  19. houly
    houly Member
    Jan 30, 2006
    231
    +5
    got it working
    thanks mate, your a diamond !
    very helpful
  20. pxr5
    pxr5 Member
    Dec 28, 2005
    649
    +70
    No problem. I know as I did the same thing. :hiya:
  21. easyrider
    easyrider Member
    Nov 9, 2008
    2,146
    +113
    Thats exactly what my screenie shows!:p
  22. pxr5
    pxr5 Member
    Dec 28, 2005
    649
    +70
    Aha, but words paint a thousand pictures or something like that ;)
  23. johnmerrick
    johnmerrick Member
    Jan 31, 2005
    697
    +12
    I have tried the workaround and it muxed without a problem but mkv2vob stalls on 'patching dts'.
    have i missed something?
  24. girlcreeture
    girlcreeture Member
    Mar 25, 2010
    I just started running into this problem so thanks for posting this workaround! It definitely fixed the issue for me :D
  25. OLDCell
    OLDCell Active Member
    Jan 23, 2009
    2,270
    116
    +747
    Thanks for workaround, only happened today on a few mkv's so I have remote desktop on my PC from work to set them going and put them through mkv2vob after.
    So when i get home I can just flick on the XBMC box and start watching!! Yay :smashin:
  26. tovansky
    tovansky Member
    Sep 7, 2010
    I specifically registered just to thank you for the tips. worked like charm for me. tsmuxer.exe no longer crashes.
  27. Axum
    Axum Member
    Aug 27, 2007
    6,137
    +815
    mkv2vob is being updated soon so hopefully this won't be an issue, although i'm not sure if the update addresses this problem.
  28. EmptyG
    EmptyG Member
    Oct 15, 2010
    Thanks for this post! I just found this via Google and wanted to register just so I could say thanks. This was bugging me too and it worked perfectly. Keep up the great work!!! :)
  29. SkepticOwl
    SkepticOwl Member
    Oct 17, 2010
    Worked perfectly :) You saved me a lot of aggravation.
  30. saayinla
    saayinla Member
    Feb 11, 2008
    272
    +5
    Thanks for this...
