Mitsibishi DLP and black spots...
Discussion in 'TVs' started by toolman35, Jan 30, 2007.
  1. toolman35
    toolman35 Guest
    I have had this 62 in. Mitsibishi Dlp for almost 2 yrs. now and Noticed a black spot a few months ago. Now I am starting to see mnore of these spots pop up all over the screen. The spots are not really noticable when watching TV only when a lighted scene comes on the if you look for them you can see them well. The first one that appeared is the largest, probably about a inch in dia.
    Does anyone know what this could be? I have someone comming out to look at this next week just thought I might get some input on this before hand.
  2. 1080 jawbreaker
    1080 jawbreaker Member
    Nov 30, 2004
    1,895
    +236
    dirt on the bulb?
  3. toolman35
    toolman35 Guest
    long time huh,.. YES! Dirt on the mirrors. I have cleaned it myself since this post. Nice TV, but next time I will do more homework
  4. larlev
    larlev Member
    Feb 14, 2008
    I have the same problem....how did you clean the mirrors?
    Sorry to reply to this ancient post.
  5. JJTye
    JJTye Member
    Apr 4, 2007
    78
    11
    +5
    I dunno, im just guessing that it might be hinge failure, from all that flexing back and forth.
    Jason.
  6. DarealJoker
    DarealJoker Member
    Mar 16, 2008
    2
    Problem: Dirty mirror as stated earlier. There are 10 screws to remove on the back of DLP TV (Mitsubishi 62") across the top and down the left and right sides. Then remove the from bottom plastic gray cover. (no screws it just snaps in place, the long slinder gray piece across the bottom.) Once the cover is removed in the bottom middle you will need to remove 4 more screws and take out the bottom middle plastic piece (its the piece that has the warning sign about not looking into the light). This is where you disconnect the from control panel before removing the entire from piece. The last you loosen will be the bottom left & right screw holding the front screen in place. Take is off then you will need to clean the bottom mirror just over the lens. Doing this cleared all spots and restored the color and brightness. Picture looks brand new. I just wish I knew about this sooner.
  7. pops107
    pops107 Member
    Apr 4, 2007
    1,182
    38
    +16
    I have a samsung 50" dlp with a white pach in the lower center of the picture what did you clean the mirror's with?
  8. DarealJoker
    DarealJoker Member
    Mar 16, 2008
    2
    I'm sure any cleaning solvent and rag would work but, I used what I normally clean the front screen with (a Monstor [MicroFiber] cleanning brand cloth I picked up from Fry's Electronics and the Monster ScreenClean solution.
  9. ilrep49
    ilrep49 Guest
    I'm assuming this is to remove the large cover on the upper/rear half of the TV? Not the lower section where the a/v connections are? I just found this posting after I called Tweeter and found out it was $395 for them to come out and diagnose my "problem". This was a real help!!! I just don't want to remove the wrong section!!! Thank you!
