Minimum distance between projector and screen
Discussion in 'Projector Screens' started by mobilevaleter, Apr 14, 2009.
  1. mobilevaleter
    mobilevaleter Member
    Jan 27, 2008
    148
    +9
    Hi am thinking on a projector and screen for my next upgrade but wondering if there has to be a minimum distance between the unit and the screen?
    Distance I have between my back wall and tv unit is 11.5 feet will this limit the size of viewing screen i can have.
    sorry for sounding thick but i don't really know about these things lol :smashin:
  2. Showoff
    Showoff Member
    Dec 15, 2008
    877
    46
    +173
    Depends what projector you want as every projector is different and depending on what screen size you want, yes there will be a minimum distance.
    Check out the web site of the projector you are looking at as they virtually all have this info on them. Or look HERE. If you still can't find it yourself then ask on here.
