[MERGED]Marantz AV Receivers SR5004/SR6004 Owners Thread
Discussion in 'Integrated Amplifiers & Receivers' started by Tone-uk, Aug 21, 2009.
  1. Tone-uk
    Tone-uk Member
    Apr 3, 2009
    1,342
    63
    +167
    Marantz have hosted their little party for the above models (and the NR1501) in the US.
    Marantz Hosts SR6004, SR5004 and NR1501 AV Receiver Reception: BigPictureBigSound
    The suggested rrp for the sr6004 has been £799. Not sure about the sr5004 - probably £599??.
    Look good to me! Obviously the big issue some have with Marantz is their inability to apply Audyssey EQ when bitstreaming audio - I doubt this has changed but, maybe it has?
    Full specs from Marantz website
    Marantz America | NR1501 *** COMING SOON *** Dolby TureHD / dts-HD Master Audio AV Receiver
    Nice 20,000 microfarad capacitors in the sr6004 too. Something you don't often see put in the spec sheet for av receivers.
    • Thanks Thanks x 1
  2. Passingbat
    Passingbat Active Member
    Feb 20, 2003
    7,179
    +1,239
    Now, if they fix this, I'll be a fan, I promise :D
    I believe they have the same parent company as Denon so getting that sorted, surely shouldn't be a problem (as the Denons don't have that problem).
    I know some people switch Audessy off (and it seems to be the recommended way with this years Denons), but I love options!
  3. snowmonkey
    snowmonkey Member
    Aug 19, 2009
    63
    get a blu ray player that can output the bitstream and then you can use audessy eq in the amp, marantz's new bd7004 could well fit the bill, this combo is my next intended purchase once they hit the shops
  4. dante01
    dante01 Well-Known Member
    Mar 5, 2009
    25,874
    +4,560
    I don't think you've grasped what the issue was with the previous Marantz models? If the new models still suffer from this problem then doing as you suggest would actually instigate the issue. The issue is with not being able to use Audyssey EQ when bitstreaming audio to the receiver.
  5. marelc
    marelc Member
    Aug 28, 2009
    4
    I'm after 5004 or 6004 mailnly for Audyssey dynamic volume and eq. Just sold my sr5002
    Can you let m know what do you mean by bitstreaming audio. Optical? coaxial hdmi ?
  6. dante01
    Mar 5, 2009
    25,874
    +4,560
    Bitstreaming is the streaming of audio in its raw encrypted format to the AV amp so that the amp decodes it. The alternative is to let the player decode the audio onboard prior to streaming it as LPCM to the AV amp.
  7. marelc
    marelc Member
    Aug 28, 2009
    4
    So really most of the time I let the amp decode audio as its sent in dolby, dts etc. I only use lpcm when playing MP3 when dvd player sends it via optical as pcm. Thanks for the advice. I will have to check this before buying. :smashin:
  8. marelc
    marelc Member
    Aug 28, 2009
    4
    Can you advice where did you hear about Marantz not able to use Audyssey EQ when bitstreaming audio. I'm about to buy sr5004 or sr6004 as soon as they are available. I dont want to spend money and later not be able to use it.
  9. dante01
    Mar 5, 2009
    25,874
    +4,560
    I believe it is stated in both the 5003 and 6003 manuals that Audyssey EQ is useless for DD+, TrueHD and DTS-HD material. Audyssey EQ cannot be applied when these formats are bitstreamed to the receivers.
  10. Passingbat
    Feb 20, 2003
    7,179
    +1,239
    This was an issue on the previous Marantz recievers; no one knows if it will be fixed on the new ones (here's hoping it's fixed!)
    There's some detail and a link I posted here:
    http://www.avforums.com/forums/9505846-post672.html
  11. taubenspikes
    taubenspikes Member
    May 20, 2008
    28
    3
    +3
    i wanna buy a new receiver in the next weeks, but i need a advice which one to choose.
    the onkyo 707/807 or the new marantz 6004. i wanna use the two high/wide speakers, but dont know which soundprozessor is the better one (Audyssey DSX vs. DOLBY IIZ). maybe someone has heard the both and can write a little review. Thanks.
  12. baccattack
    baccattack Member
    Jul 27, 2000
    225
    +21
    Suprising. I thought Marantz didn't do yearly updates of their receivers or is this only at the lower end? There were no updated 7xxx/8xxx models last year.
  13. Passingbat
    Feb 20, 2003
    7,179
    +1,239
    Sadly, it hasn't been fixed:thumbsdow
  14. aldente
    aldente Member
    Dec 28, 2008
    17
    3
    +5
    To Marantz SR6004 owners,
    Does anyone know whether this AV receiver accepts the 4mm banana plug on the speaker posts of the UK model? If so, does yours require strong force to push one in?
    According to the brochure from Marantz Europe website, this receiver appears to have binding posts similar to those found on the banana-plug compatible speakers which have concealing plastic caps for the holes. However, the UK model may differ. The manual available from the website, as most other manufacturers, mentions no banana plugs.
    I heard on a thread somewhere I do not remember that the previous SR6003 did accept banana plugs, and I am hoping the new one also does.
    Thank you in advance for your info.
  15. Aegdju
    Aegdju Member
    Apr 28, 2008
    3
    I'm a new and happy owner of a Marantz SR6004.
    So far I'm very satisfied with it, especially by the impressive sound stage it shows with both stereo and multichannel. The musicality is also a clear step up my previous receiver (Denon Avr 2800)
    Though, before more serious listening, I'm still setting all the parameters and experimenting the surrounds modes.
    I have a question here, for owner of the 6004/5004 (or 5003/6003) :
    In short :
    Is it possible to have or save different settings per input source ?
    In detail :
    I have a PS3 hooked on HDMI1 and a satbox (canal + FR) on hdmi4 and I'd love to have some settings different for each of them (mainly the settings that aren't directly on the remote like : HT-EQ on/off and dynamic EQ adjust offset)
    Thanks,
  16. aldente
    aldente Member
    Dec 28, 2008
    17
    3
    +5
    Like you, I am also a new happy owner of SR6004. As far as I have explored, I do not think there is such a feature on the model. It would be great if it were capable of saving profiles for each input source though.
  17. ani4ani
    ani4ani Member
    Nov 12, 2001
    1,948
    +177
    I really like the look of these amps, but I seem to have a peculiar problem that might actually prevent me having one. My AV stand has a space for an amp that is 440mm wide which is fine for "normal" seperates [430mm?], however looking at the specs for this amp, it says it is 440mm wide..which seems rather odd.
    May I ask one of you lucky owners to comfirm that is the case?
  18. aldente
    aldente Member
    Dec 28, 2008
    17
    3
    +5
    Yes, it is 440mm in width. I expect AV racks/stands to allow a clearance of 20-30mm each side, for your fingers as well as heat dissipation. With this in mind, I bought a stand wide and sturdy enough, and SR6004 was not a problem in my case.
    • Thanks Thanks x 1
  19. ani4ani
    ani4ani Member
    Nov 12, 2001
    1,948
    +177
    The stand I have has "ventilated" sides, i.e. they are not solid. Just looking at the photos of the unit it seems that the front "face" is slightly wider, than the main chassis. Is the 440mm the front or the main chassis. Thanks for your help
    Pete
  20. aldente
    aldente Member
    Dec 28, 2008
    17
    3
    +5
    There is a rip of 3mm on each side on the front. The 440mm includes these rips.
    • Thanks Thanks x 1
  21. Simon Young
    Simon Young Member
    Sep 8, 2004
    428
    28
    +64
    My Harman/Kardon AVR 4550 is over 6 years old now and I think it's upgrade time. I've got my eye on the Marantz SR6004 - anyone bought one yet? Will I hear a difference in musicality between the SR5004 and the SR6004?
  22. Aegdju
    Aegdju Member
    Apr 28, 2008
    3
    Quick question to other owners of the 6004 :
    I can hear a low humming sound coming from the receiver (from the power unit i guess) when i am close enough (10 or so centimeters). Are your 6004s doing that too ? I'm pretty sure mine was totally silence the first day when i installed it.
  23. lubej
    lubej Member
    Dec 12, 2006
    93
    +4
    Hello
    Do you maybe know if marantz will release sr4004 on the market.
    They removed 4003 from web site but did not add new model 4004
    Thank you.
    Br
  24. confused88
    confused88 Member
    May 15, 2009
    1,246
    +70
  25. aldente
    aldente Member
    Dec 28, 2008
    17
    3
    +5
    Mine does not have such a humming sound.
  26. confused88
    confused88 Member
    May 15, 2009
    1,246
    +70
    A few of questions for SR5004/6004 owners.
    Could anyone confirm if the "Audyssey problem" is still there ? If so do you send HD audio as LPCM ?
    There were a few reports that this is not possible with Sony Players as they force bitstreaming if the receiver has the ability to do the decoding. Has anyone used the Marantz with a Sony Bluray player?
    Thanks.
  27. dante01
    Mar 5, 2009
    25,874
    +4,560
    http://www.avforums.com/forums/av-a...ed-drive-monitor-audio-rx8s.html#post10723515
    http://www.avforums.com/forums/av-a...marantz-inability-apply-audyssey-eq-mean.html
    • Thanks Thanks x 1
  28. confused88
    confused88 Member
    May 15, 2009
    1,246
    +70
    Thanks. I have read these posts. That problem had put me off the SR6003 in the first place but now Electrical Store | Electrical Appliance Retailer | Online Shop have the SR6004 together with the S360 for £760 and it seems tempting. So I am wondering if the S360 has the same problem as the S550. Not too far from where I live though so I might pay them a visit.
  29. Simon Young
    Simon Young Member
    Sep 8, 2004
    428
    28
    +64
    Wow, I just noticed this! It's actually cheaper to buy the 6004 with the S360 than it is to buy the 6004 separately! :eek:
  30. Tone-uk
    Tone-uk Member
    Apr 3, 2009
    1,342
    63
    +167
    In regard to Sony blu-ray players forcing bitstreamed hd audio (because the sr6004 can internally decode it), I'm sure the (part?) solution is to set the Sony to output "mix" rather than "direct". It is only under "direct" that the Sony picks and chooses the receiver capabilities. Using the "mix" setting, secondary audio is also sent (not possible when bitstreaming). Check this thread for a bit more info http://www.avforums.com/forums/blu-...can-decode-multichannel-lpcm-over-hdmi-2.html
    Also, I've found this thread with posts in regard to a finnish hifi magazines group review. The SR6004 was up against the Yamaha rx-v1900, Denon 2310, Onkyo 807, Pioneer lx52 and NAD T 747. The SR6004 won but, suggests analogue inputs rather than digital.
    Summary of review near very end of thread (look for the post dated 25/10/09 @ 14:18)
    Google Translate
    • Thanks Thanks x 1
