Media & File Server Bundle for the Foxsat HDR - Release 4,0 - PART 3
Discussion in 'Freesat Forum' started by raydon, Jul 30, 2012.
Thread Status:
Not open for further replies.
  1. MobileUser
    MobileUser Member
    Dec 8, 2011
    16
    Just (yesterday) installed "the" package on a Fox T2 using a flash card to store the sofrware.
    The EPG function doen't work, I get "no cached EPG data" on the web page (EPG is working on the TV side).
    I left the box active all night in the hope that something would download - zilch.
    Have I broken something (see previous tribulations) or won't the memory stick (slow speed) store the cache?
    As a subsidiary - from whence is the EPG information extracted; I'm assuming in the data stream from each MUX, or is there one master source?
    tks.
  2. REPASSAC
    REPASSAC Active Member
    Jan 11, 2011
    2,664
    +401
    MobileUser - I think you have the wrong forum - this is the freesat+ forum and this thread concerns the Foxsat HDR.
  3. REPASSAC
    Jan 11, 2011
    2,664
    +401
    Yes, it could say that anyway - when checking for updates the latest version of the def auth data is downloaded - see if it is now present.
  4. MobileUser
    MobileUser Member
    Dec 8, 2011
    16
    Sorreee...
  5. gigaday
    gigaday Member
    Nov 7, 2012
    12
    Where should I look for "def auth data"?
    I still see "aucDefaultAuthority {}" in the raw EPG data for BBC4.
    Code:
    {serviceid 6316 eventid 54631 starttime 1354044600 duration 1800 encrypted 0 name {Great British Railway Journeys} descr {4/20. Pontefract to Bridlington: Documentary series with Michael Portillo. Michael searches for the last liquorice grower in Pontefract and goes fishing for sea bass in Bridlington. [AD,S]} warning {} contentcode 2 contenttype {News/Current affairs} ECRID /24103O SCRID /L54LN3 RCRID {} usLcn 107 szSvcName {BBC FOUR} aucDefaultAuthority {} hSvc 0 Magic 702}
  6. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,904
    163
    +3,117
    Seems to work fine, only tried a short instant recording with no problems.
    Will report after a few days timer recording activity.
  7. raydon
    raydon Active Member
    Apr 9, 2010
    1,120
    116
    +1,076
    Use the "Update package list from Internet" button on the package management page of the web interface. This will also update the DefAuthInit.sql file which resides in folder /opt/epg.
  8. gigaday
    gigaday Member
    Nov 7, 2012
    12
    Thanks very much. I now have /opt/epg/DefAuthInit.sql dated 27 Nov.
  9. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    Sorry, no. That might make things uncomfortable for raydon and the crew here.
  10. MobileUser
    MobileUser Member
    Dec 8, 2011
    16
  11. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    No, the program is designed to find all the files it needs from the directory it's run from. However, putting it in /tmp means that the patching program and its temporary data is cleaned from the system when you reboot.
  12. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    Revised patch. This doesn't fall through to the original settop program if the patched one crashes or exits (this would cause lock-ups). Thanks to raydon for the tip.
    If you've already applied the older patch, use the removal procedure first.
    I may in the near future attempt to put together an opk package that can be put on a USB stick and installed that way. (Assuming the format allows install and removal scripts, that is.)
    • Thanks Thanks x 5
  13. caldirun
    caldirun Member
    Mar 18, 2007
    358
    +17
    I have 2 HDRs connected to a router (1 via another route used as a switch to allow more inputs)
    The directly connected HDR will update the packages, returning---
    opkg update
    Downloading
    http://hummypkg.org.uk/foxsat/base/Packages.gz.
    Inflating
    Updated list of available packages in
    /opt/var/opkg/base.
    Updating package meta information
    Done.
    The other returns,----
    opkg update
    wget: bad address 'hummypkg.org.uk'
    Downloading
    Collected errors:
    * opkg_download: Failed to download
    http://hummypkg.org.uk/foxsat/base/Packages.gz,
    wget returned 1.
    Updating package meta information.
    Everything seems to work except this update, any idea why? please
  14. adrianf36
    adrianf36 Member
    Jul 28, 2011
    410
    63
    +476
    Difficult to be sure from the above but it looks like there could be a DNS name resolution problem with the second HDR. Do other Internet based services (such as iPlayer) work okay on the same box?
  15. caldirun
    caldirun Member
    Mar 18, 2007
    358
    +17
    Sure, iplayer works fine
  16. GaseousClay
    GaseousClay Active Member
    Jan 11, 2011
    3,198
    +1,412
    I can't remove this nowster, :(
    Code:
    login as: root
    root@192.168.1.68's password:
    Foxsat-HDR~# ./runme.sh remove
    -sh: ./runme.sh: not found
    Foxsat-HDR~#
    it might have something to do with me making a right pigs ear installing it :blush: :rolleyes:
  17. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    Use the same instructions as installing, but use "./runme.sh remove" before "./runme.sh".
    • Thanks Thanks x 1
  18. GaseousClay
    Jan 11, 2011
    3,198
    +1,412
    :thumbsup: That looks like it's done the trick.
    Many thanks. :smashin:
    GC
  19. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    I've now got the tools to make an opkg. That should make installation easier for most.
    • Thanks Thanks x 2
  20. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    Here you go. Unzip the contents of the attached file, drop it in the root of a USB stick, and insert the stick into your HDR (must be running custom firmware already) which is already switched on. Then wait a minute.
    Put the HDR into standby, then power it up again. Remove the USB stick and have a look at settop-patch_4.0.9_mips.opk.install.log. It should end with "Install done" and not contain any error messages.
    Note that (as it's not from the "official" repository) this package does not show in the web interface's list of installed packages.
    To remove it, you need to telnet/ssh in and type
    Code:
    opkg remove settop-patch
    and then put the HDR into standby and power it up again.
    To check it's installed, use telnet to check whether "settop-patch" is listed amongst the installed packages, using
    Code:
    opkg list-installed
    If you've installed the patch previously using the "runme.sh" method, this package will safely overwrite that -- there's no need to remove the old patch beforehand.
    • Thanks Thanks x 35
    • Useful Useful x 1
  21. adrianf36
    adrianf36 Member
    Jul 28, 2011
    410
    63
    +476
    Odd then. And it's definitely not a transient problem is it? The problem is permanent?
    If iPlayer works then it would imply that all networking, internet access and name resolution is working okay. So no reason I can think of why the package management update shouldn't also work.
    Stumped I'm afraid. Sorry about that. Hopefully someone else will have some ideas.
  22. REPASSAC
    Jan 11, 2011
    2,664
    +401
    Telnet to your Foxsat and enter
    nslookup hummypkg.org.uk
    nslookup bbc.co.uk
    If the first fails retry as:
    nslookup hummypkg.org.uk 8.8.8.8
    Please post results.
  23. af12345
    af12345 Member
    Mar 2, 2011
    41
    +26
    If you drop it on a web site somewhere (dropbox shared folder is probably favourite) then people just need to telnet in and run opkg install <URL to file> - may be easier for some.
  24. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    Too error prone in my experience. See the moans above from people complaining about having to use the command line.
  25. caldirun
    caldirun Member
    Mar 18, 2007
    358
    +17
    Thanks for the reply
    I have just tried above and it worked fine, I have now updated the packages with no problem.
    Only thing I can think of that I have done differently, I powered the PC up before the Humax tonight and the other way around this morning.
    Update
    I was trying to install Media Tomb to stream music to my new AV receiver as I have been working since Sunday to get Windows media player from my PC to show up, Media Tomb is now showing on the AV receiver, a great result, just need to find out how to use it!
  26. caldirun
    caldirun Member
    Mar 18, 2007
    358
    +17
  27. nowster
    nowster Member
    Apr 6, 2011
    285
    43
    +114
    It should help those who want to watch their shows on other devices using Twonky or MediaTomb.
  28. gigaday
    gigaday Member
    Nov 7, 2012
    12
    Would I be right in thinking that this can't be fixed in the web interface?
    It seems like a similar problem to the missing auDefaultAuthority but harder because the data missing is per program rather than per channel.
  29. CPN
    CPN Member
    Mar 31, 2010
    167
    +11
    Indeed it will and a belated thanks for all your efforts in this regard! :thumbsup:
    A worthy additional feature added to the custom software of Raydon's :)
  30. Monster900
    Monster900 Member
    Dec 30, 2011
    95
    +5
    It does indeed. Absolutely fantastic and many thanks.
    It works here on firmware v4.0.8 and is a huge step forward for those who want device independent HD content.
    :thumbsup:
    Now just got to figure out how to make the home network fast enough to stream HD content without juddering.
Thread Status:
