MC Escher 'Waterfall' working model realised...
Discussion in 'General Chat' started by Chadford, Feb 19, 2011.
  1. Chadford
    Chadford Active Member
    Mar 5, 2006
    4,796
    +1,186
    [​IMG]
    Waterfall (M. C. Escher) - Wikipedia, the free encyclopedia
    Watch 1080 full screen...
    YouTube - Waterfall
    How it's done?...
    Is this how the Escher Waterfall machine works? - Boing Boing
    ...Hmm, don't think the above explanation is quite right, I think the woodworking is explained correctly though.
    I think it's all filmed in one cut. I suspect there's batteries and a pump hidden in the base. There's a suspicious looking slot in the box where he pours the water in. I would guess half the water pours into the base section and is pumped up to the top section and is timed to look correct. The bottom section will probably have a method of recovering the water and feeding it back to box under the wheel to recycle it.
    Very impressive stuff. :smashin:
    • Thanks Thanks x 9
  2. DPinBucks
    DPinBucks Active Member
    Dec 2, 2008
    5,031
    +926
    The water going up the slope when he pours it in is Photoshopped. Look at the leading edge: it doesn't flow correctly.
    I think the construction is genuine, but it needs another look. It might be one of those illusions caused by separate bits filmed in front of each other (like the Channel 4 logos).
    There's certainly more water flowing around the waterfall and wheel than he poured in originally. I guess, as you say, it's pumped around.
  3. DPinBucks
    Dec 2, 2008
    5,031
    +926
    Hmm...
    Having looked again at the explanation link, I'm not so sure, now. It could be flowing along the ground as he says.
  4. sniffer66
    sniffer66 Active Member
    May 22, 2004
    8,216
    +1,797
    Excellent. My dad had a hardcover Escher book when I was a kid - it used to fascinate me for hours
  5. PoochJD
    PoochJD Member
    Aug 28, 2000
    11,000
    +1,916
    It's an extremely clever video clip, for sure, but it has to be 100% fake! :(
    Ignore the issue about the way the water does/does not flow, just look at how the device has been constructed - from wood. It wouldn't be physically possible to build the contraption, if you follow Escher's "design". That's the whole point of his works: that the illusion is "impossible", and that's what makes them so brilliant. :)
    Also, because of the fact the "designs" are in 2D, but use depth perception to convince the human eye that what you are seeing is a 3D image. Transferring that into actual three dimensions wouldn't be possible in my view, so the video has to be a fake.
    Still very clever though. :)
    Pooch
  6. Chadford
    Mar 5, 2006
    4,796
    +1,186
    Does this help Pooch (this is how I see it)...
    [​IMG]
    There are two independent water paths fed from the base of the thing...
    1) One that zig-zags downhill and along the floor (but looks to be going up).
    2) One that is pumped to the top of the tower and falls onto the wheel.
    He's created an optical allusion in wood so that both paths looked to be joined (but are actually nowhere near each other). The other very clever bit is that he's timed perfectly the initial flow of water so that when the water hits the end run on the floor, the second path is just pumping to the top and thus they seem to be the same flow (if you look carefully they are visably not the same flow). :)
    • Thanks Thanks x 1
  7. Mr Incredible
    Mr Incredible Well-Known Member
    Dec 2, 2003
    20,426
    171
    +7,826
  8. Toko Black
    Toko Black Active Member
    Jun 3, 2010
    4,127
    +819
    I think the model in the first video is part CGI - where the waterfall drop is larger than the height of the base where the wheel it is potentially CGI because when he walks past the shadows don't match and that is the optimum point for doing it.
