Marantz SR6004 now red light blinking help
Discussion in 'Integrated Amplifiers & Receivers' started by Madasafish110, Jul 24, 2010.
  1. Madasafish110
    Madasafish110 Member
    Dec 3, 2005
    42
    I have a 10 month old Marantz SR6004 AV Amp
    I went to turn it on the other day and the red light just started flashing.
    I really dont want to have to send it back as its a 200 mile trip there and back.
    I have read a couple of old threads, about this problem, Where is the surge / fuse trip ?? thats is mentioned.
    I hope someone can give me some help, it would be appreciated.:lease:
    Thanks again
    Kevin
  2. Madasafish110
    Dec 3, 2005
    42
    Has no one got any advice for me, as regards to my Marantz SR6004 AV AMP problem.
    I just turned it on the other day and the red light started blinking very fast.
    Please help some one, as I dont want to have to send it back
    Kev
  3. reevesy
    reevesy Active Member
    Feb 20, 2005
    3,763
    +270
    ...just a guess...but can you do a system reset back to factory settings?
    .....also guessing but any fuse issues would mean a dead amp with no power?
    cheers.
    • Thanks Thanks x 1
  4. a8ch
    a8ch Member
    Oct 4, 2006
    1,478
    +112
    As far as I can see a red flashing power light is indicative of thermal shut down to protect any damage to the amp. Check out your speaker connections for shorts between pos+ & neg-.
    • Thanks Thanks x 1
  5. Madasafish110
    Dec 3, 2005
    42
    I have tried all I can do.
    It still does it with everything unplugged.
    I just hate having to send it back. I bought it from Sevenoaks in tadcaster, i think it was tadcaster.
    Just dont want to be without it for weeks on end:rolleyes:
    Thanks any way
    Kev
  6. a8ch
    a8ch Member
    Oct 4, 2006
    1,478
    +112
    Found this in another thread, give it a try?
