Manta 3D 42" LCD TV £350
Discussion in 'TV Technology: Smart TV, 3D, Ultra HD, 4K' started by thedoctor2007, Jan 2, 2012.
  1. sklskl
    sklskl Member
    Apr 2, 2010
    42
    Xbox 360, Sky and a pc that has vga/dvi output.
    How much would a hdmi video card set me back. Will the picture distance be great?
  2. flash67
    flash67 Member
    Feb 20, 2006
    11
    +10
    When I connected my manta to my pc with either vga or dvi, the tv wouldn't let me select 3d mode. However now that I am using the hdmi output of my computer, 3d mode works just fine. This is useful if you plan to watch any 3d movies or games on your pc.
  3. celsius
    celsius Member
    Jun 1, 2008
    458
    28
    +39
    A new card will set you back £2x.00
    For a used one, it costs peanuts.
    Apart from better picture, you get sound without connecting another audio cable.
  4. mocca
    mocca New Member
    Dec 22, 2006
    1,566
    +106
    Does the manta have 3d eye correction?
  5. mocca
    mocca New Member
    Dec 22, 2006
    1,566
    +106
    If your card has a dvi then you can use a dvi to hdmi converter which are a few pound.
    I use a dvi to hdmi cable ;)
    When you tried dvi did you use a dvi to vga converter?
  6. Only777
    Only777 Member
    Sep 9, 2004
    586
    +66
    it has an option to select L/R if thats what you mean?
  7. mocca
    mocca New Member
    Dec 22, 2006
    1,566
    +106
    Thanks Only777 , that's the info i needed, a cheap buidget set that has left/right eye swap.
    Makes me laugh that phiilips overpriced budget 7606 3d range has no eye correction!
  8. So Solid Jedi
    So Solid Jedi Member
    Jun 15, 2006
    44
    In case people don't know, Dabs.com are currently selling the Manta 32" 3D set at £279.98, a very tempting price. :eek: was gonna get one for me nan, but no Freeview HD was the deciding factor unfortunately :(
  9. bonzobanana
    bonzobanana Active Member
    Aug 21, 2001
    3,408
    +222
    At one point Marks and Spencers were selling the very similar Cello 32" 3D model at £249 delivered with a 5 year guarantee plus quidco. So the dabs offer isn't close to that value. Not knocking it but there have been better prices. I think you can get the 32" cello delivered from makro for £264.
  10. Bluevg
    Bluevg Member
    Feb 22, 2012
    4
    :confused::facepalm:
    Any members know of any sites to buy cheaper than on the Amazon, please post..either Manta or Cello, need to buy ASAP.
    Also was wondering, has any buyer mounted this TV on the wall? Is wall mounting 3D tv's advisable?
    an utter novice..so please be kind:lease:
    :lease:
    BlueVG
  11. Ari33
    Ari33 Member
    Jan 22, 2009
    1,007
    +198
    Passive Tv's really need to be mounted centre of the screen at eye level, if you do mount it higher up on a wall it will need to be tilted down which could limit the viewing angle/area for other users sittting elsewhere in the room.
  12. bonzobanana
    Aug 21, 2001
    3,408
    +222
    Cello is currently £299 at Marks and Spencers with a 5 year guarantee. Definitely worth the extra bit of cash for the extended warranty. If the panel fails in 4 years you may get a replacement tv out of it.
    These are budget sets and the extended warranty is much more worthwhile getting.
  13. Bluevg
    Bluevg Member
    Feb 22, 2012
    4
    Thank you Ari33, I guess I will need to buy a stand, it makes sense.
    Cello@299 is the 32", not the 42" 3D like the Manta, am holding on to a further price drop & will grab it if it touches 300, that should cover my stand costs too.
    Manta 3D LCD4214 42-inch Widescreen 1080p Full HD 3D: Amazon.co.uk: Electronics
    http://www.marksandspencer.com/Cell...&pf_rd_i=0&pf_rd_p=215485807&pf_rd_s=center-3
    Any suggestions for a decent low stand for the 3D tv?
    Also, am thinking of buying the Sony Blu Ray player,,
    Sony BDPS480B.CEK 3D Blu-Ray Disc: Amazon.co.uk: Electronics
    Advices?
  14. mike7
    mike7 Active Member
    Jan 3, 2005
    3,783
    +327
    TV's are supplied with a stand ??!???
  15. Bluevg
    Bluevg Member
    Feb 22, 2012
    4
    Mike7, No..sorry for the confusion.
    I meant to say that when the price drops to 300, I will buy the 50£ stand with it.
    Any advice on the combination of a Blu Ray with the Manta?
  16. paulmcp2403
    paulmcp2403 Member
    Mar 29, 2005
    1,153
    48
    +72
    I couldnt see it....do you have the link ???:thumbsup:
  17. bonzobanana
    Aug 21, 2001
    3,408
    +222
    It was £299 but its gone back up again now. Might be worth keeping an eye on.
  18. scooby9858
    scooby9858 Member
    Feb 25, 2012
    2
    i have tried 3d sbs movies on a usb drive on both the manta 3d tv and the cello 3d tv and video works but audio doesn't work.yet everyone of them work on samsung tv.anyone any ideas what audio format works on cello and manta.
  19. Ari33
    Ari33 Member
    Jan 22, 2009
    1,007
    +198
    The LG 3D sets have the same issue, they wont play MKV audio files. I just convert mine to AC3 audio format and it works fine, I assume the Manta will be similar..
  20. bonzobanana
    Aug 21, 2001
    3,408
    +222
  21. scooby9858
    scooby9858 Member
    Feb 25, 2012
    2
    thanks mate i have just tried it and ir works on both the cello and manta.
  22. headchef
    headchef New Member
    Jan 15, 2014
    Hi there. I have had my manta 3d tv for 2 years and i can tell you it is well worth the money. Cheers
