Mac Mini vs. Plasma
Discussion in 'Apple Mac' started by keiyuu, Feb 21, 2012.
  1. keiyuu
    keiyuu Member
    Dec 4, 2009
    15
    I've the same issue with 2 different plasma screen by panasonic with a mac mini bought in september 2010.
    The tv is connected with hdmi cable, with the presence of white objects on the screen there's like an halo following it across the width. Let me explain better, take "the hangover" (1 or 2 it's the same) ending credits with the static pictures on the left and the credits rolling on the right. When I watch this I see these light shadows over the pictures showed on the left that move alongs the credits on the right.
    Any solution? Or it's just a common plasma issue?
  2. stevelup
    stevelup Active Member
    Aug 13, 2002
    5,700
    +712
    That's fairly normal plasma behaviour, but only if you have it set too way bright.
    Are you using Dynamic mode by any chance? Exactly which plasma displays are they?
  3. keiyuu
    keiyuu Member
    Dec 4, 2009
    15
    P46S10 and P50G30, I'm using cinema mode (untouched) with mac mini and thx with my LG blu-ray player, I noticed the same thing scrolling a blu-ray menu one time.
  4. NewfieDrool
    NewfieDrool Active Member
    Dec 1, 2008
    3,515
    +1,008
    Does this only happen only when you have your Mini plugged in.
    I have a Panasonic z1 and have not seen this before but I have not got a Mini.
