Looking for Small High Quality Radio/CD unit?
Discussion in 'Hi Fi Systems & Separates' started by Mark Ward, Jan 20, 2004.
  1. Mark Ward
    Mark Ward Member
    Sep 12, 2001
    1,777
    41
    +18
    I need to get a reasonably compact radio/cd player for the kitchen. I've read the thread about kitchen solutions, but what I'm after is more of a mini-boombox solution.
    I'd like a good quality, fairly powerful one that's not massive. Great sound is fairly important though. Budget, hopefully well under but £300MAX. The bose wave radio get mixed opinions and is a little over my intended budget.
    Include SACD an/or digital radio and I may stretch to a little more:)
    Note I definitely want a portable, single, self contained unit including the speakers. I don't want to run a second zone from my HT system.
    Anyone have any recommendations?
    Cheers,
    Mark.
  2. engaged
    engaged Member
    Jan 12, 2004
    179
    Someone else had a very, very similar question here a few days ago and I suggested, as I am about to again, the Denon DM-31 which can be found (excl. spkrs) for £180 jst about everywhere. Admittedly, speaker aren't self-contained but you'd then be able to choose speakers as small or as large as you prefer - or your kitchen allows.
  3. bobbypunk
    bobbypunk Guest
    This Teac unit is meant to be fairly good can't remember the price but it's well under £300
    SLD90
    Individual looks?!?
    Colour choice?!?
    But it's meant to sound good.
  4. Mark Ward
    Mark Ward Member
    Sep 12, 2001
    1,777
    41
    +18
    Thanks to both of you, I did read the other thread as I mentioned in my first post, however the difference is that I want a portable solution. The device will need to sit on a welsh dresser so a Mini-Hifi solution wouldn't be ideal as these mini systems are actually quite deep and require speaker cables to come out of the back of them.
    I'm thinking good, powerful yet compact boom-box type solution.
    Anyone got any ideas for a 1 box solution incl. speakers?
    Cheers,
    Mark.
  5. common
    common Member
    Mar 5, 2001
    1,384
    41
    +8
  6. engaged
    engaged Member
    Jan 12, 2004
    179
  7. Mark Ward
    Mark Ward Member
    Sep 12, 2001
    1,777
    41
    +18
    Common:-
    Looks nice :) howver I'd get shot if I spent that on a kitchen solution. Also, it's hard to gauge the dimensions, looks quite tall.
    Won't rule it out though,
    Thanks,
    Engaged:-
    That looks absolutely ideal:) I had no idea they made them. Now to hunt for the best price.
    Cheers,
    Mark.
  8. engaged
    engaged Member
    Jan 12, 2004
    179
    Doesn't look like many places sell the Creative CD740 - yet!
  9. Mark Ward
    Mark Ward Member
    Sep 12, 2001
    1,777
    41
    +18
    Doesn't look like any places sell the Creative CD740 - yet!:(
    It is against my religion (Orthodox Tightwad) to pay RRP and buy online.
    I'll keep hunting the
    Teac Nostalgia is another possibilty, though the wife doesn't like the look of it.
  10. CJROSS
    CJROSS Active Member
    Nov 16, 2000
    5,064
    +357
    Mark everything you are looking for is available in the Bose Wave CD/adio a fine sounding little unit (if a little pricy IMHO rrp £395) a friend has one and it sounds very nice, but it is roundly beaten by the Denon DM31 (which has separate speakers of course and with £100 speakers attached is £100 less) But for your needs I would recommend it ie and “all in one”. I think it sound fine TBH you are hindered by the need to have the speaker attached.
    http://www.bose.co.uk/home_audio/wave_systems/radio_cd/
    One other to look at is Sonys little CD/MD/Tuner system 333XT with Net USB functionality. £250 and specced beyond belief IMHO (just tape the speakers to the main unit)
    [​IMG]
  11. Bassbin
    Bassbin Member
    Mar 16, 2003
    2,395
    48
    +57
    Could try one of these Argos had them in the sale at £49.99 no longer on their site but the code is 512/6202 Not exactly hi-fi but looks the part. I've tracked one down at my local store and am planning to get it tomorrow.
  12. Mark Ward
    Mark Ward Member
    Sep 12, 2001
    1,777
    41
    +18
    Thanks for the suggestions guys, I'm trying to win the wife over on the Teac Nostalgia, 20Wpc 3"Sub and onlty £99 at Empire right now. She REALLY doesn't like it.
    I really didn't want to go the bose route as it's over my absolute maximum and I've heard mixed reports.
    Looks like the Teac:)
    Cheers,
    Mark.
  13. ncpl
    ncpl Member
    Jan 21, 2003
    349
    I bought the wife a Tivoli trannie last year for the kitchen...and she absolutely loves it. Big WAF and it sounds far better than a little box should. Tuning is also better than any other analogue radio I have ever used. Price is about £99 for basic and I think there is one that is a CD combo and you can add anothre speaker for stereo if you need that above the sound of the dishwasher !!
  14. common
    common Member
    Mar 5, 2001
    1,384
    41
    +8
