LG TV: Why is there a voice over man/woman in every program!?
Discussion in 'LCD & LED LCD TVs' started by alex98uk, Sep 24, 2010.
  1. alex98uk
    alex98uk Member
    Sep 17, 2009
    105
    I have no idea what I have done, but I have a voice over woman/man that describes the scene. For example, i'm watching friends on Channel 4 atm. Rachel clicks her fingers and a weird women says "Rachel clicks her fingers", "Rachel puts her arm around Joey".
    It was the same last night whilst watching Road Wars on Sky 3. It doesn't describe...
    "Rachel grins with a smug smile on her face"
    ... every scene, just some. I thought it was some weird feature in Road Wars, but it's happening now.
    What in Gods name have I enabled!?
  2. andy1249
    andy1249 Active Member
    May 7, 2006
    6,116
    +1,235
    Thats descriptions for the blind , I dont think its anything to do with your TV though , its an option on the Sky Service , so check whatever box you have from whatever supplier your subscribed too.
  3. alex98uk
    alex98uk Member
    Sep 17, 2009
    105
    It's a built in FreeviewHD tuner in the TV. I was playing with the remote last night, might be something on there. Any idea what the option might be called.
  4. andy1249
    May 7, 2006
    6,116
    +1,235
    • Thanks Thanks x 1
  5. alex98uk
    alex98uk Member
    Sep 17, 2009
    105
    Oh thank the lord!
  6. Arn100
    Arn100 Member
    Jan 30, 2011
    We have an LG 32LD490. This afternoon for no apparent reason the voice over, disability function, audio description came on. Took a while but worked out what to do. It comes on when volume turned down to zero. How to stop it; go to Menu, Option, Disability Assistance, select Hard of Hearing to "OFF", down to Audio Description and select to "ON", ( here's the important bit) , down to Volume and set to -1, back up to Audio Description and set to "OFF", then Exit. That'll do it. I can't see why it has a -1 and lower but luckily I don't have a disability. Hope it works for you.
  7. Paul01924
    Paul01924 Member
    Feb 10, 2013
    If your LCD TV is connected to Sky HD whether you subscribe to HD or not, press the help button on the Sky HD it will bring up Audio Description if says on press the right direction button to turn off then press Select.
    We just had a new Sky HD box fitted as the Sky + broke down,but they replaced with a Sky HD + box and it didn't do it on the old one. So I searched the settings on the HD remote and found it after a week of putting up with the annoying chatter in the background. I hope that this helps some of you!
  8. Philip4242
    Philip4242 Member
    Jan 15, 2008
    646
    28
    +85
    Paul, were you aware that you've just replied on a thread which is over 2 years old ?!?
    Check the YEAR, as well as the date and month ! :eek:
  9. arenaman
    arenaman Moderator
    Nov 13, 2009
    4,261
    +900
    And he joined just to trawl a 2 1/2yr old thread and answer it, W T F ? :confused:
  10. Curly99
    Curly99 Moderator
    Dec 29, 2006
    8,805
    +2,018
    nice welcome guys......
    Curly
  11. lampsout
    lampsout Member
    Sep 14, 2013
    Taken hours on the web to find the answer , how to switch off audio description on our LG smart TV ( paul01924 ) reply solved the problem. going to Sky help took seconds to switch audio off.
    Check LG user guide - option- check disabled assistance is off.
