LG Service Menu
Discussion in 'LCD & LED LCD TVs' started by kevchall, Oct 29, 2009.
  1. kevchall
    kevchall Member
    Oct 29, 2009
    Can someone please tell me how to get into the service menu on my 32 inch LG LH4000 Please?
  2. medl14971
    medl14971 Member
    Apr 26, 2008
    1,367
    48
    +34
    press ok on the remote and ok on the tv password is 0000
    well i think it is thats what said in the thread about the usb port
    • Thanks Thanks x 1
  3. kevchall
    kevchall Member
    Oct 29, 2009
    tryed that nothing happened, tv on or off ?
  4. Dennis585
    Dennis585 Member
    Oct 17, 2009
    26
    3
    +16
    if your firmware is above 3.15 the double ok doesn't work anymore.
    you will have to downgrade to 3.15.
    • Thanks Thanks x 1
  5. kevchall
    kevchall Member
    Oct 29, 2009
    my firm ware is 3.24 how do i down grade
  6. Dennis585
    Dennis585 Member
    Oct 17, 2009
    26
    3
    +16
    HOW TO DOWNGRADE FIRMWARE AND ACTIVATE THE USB
    DOWNGRADE (read first)
    ok , create a folder on your USB stick called LG_DTV and put the 3.15 firmware in that folder (dont put another folder in the folder just the firmware itself) and Insert USB stick into TV, (if it doesnt read it automatically) then press MENU and choose OPTION (but dont press OK) but press the FAV button 7 TIMES to get upgrade screen on and choose firmware to upgrade / OK.... - failing that, repeat but press '7' 7 times instead of 'fav' which will get the basic upgrade screen on
    - downgrade the firmware and restart TV
    ACTIVATE USB
    hold down OK on remote and OK on the TV for about 5 secs (be sure to point remote at TV) then it will ask for password - press 0000 and it will take you into service menu = go to no. 2. TOOLS OPTION 3 and change JPEG to 1 and DIVX to HD (dont change ANYTHING else or you will break TV and NO bluetooth doesnt work unless your TV comes with it)
    UPGRADE
    following the downgrade guide but put the 3.40 firmware into the LG_DTV folder (deleting the old one) and insert into TV and upgrade, as the firmware is newer than in the TV it may read the USB stick without having to press FAV or 7 seven times...
    CLICK THANKS IF YOUR HAPPY WITH THE HELP
    <!-- / message --><!-- sig -->
    • Thanks Thanks x 4
  7. kevchall
    kevchall Member
    Oct 29, 2009
    thanks for help watch moves now from usb stick:clap::thumbsup:
    down graded to 3.15 works fine i had 3.24. thanks again
  8. 10ROV
    10ROV Member
    Dec 5, 2009
    7
    I think I just made a disaster :mad:
    Today I bought a LG 32LH3000
    I had the softwear V3.48.00
    I did exactly what you said: downgrade at 3.15 and after that I upgraded my LCD at 3.40
    I mention that immediately I downgrade the soft version I lost the colors...I belive that in this moment I have 64 :eek: !!! and in stand by mode it show me the message: "Not programmed"
    I need help immediately please :lease:
  9. martysport
    martysport Guest
    Really? mine is 3.31 and it works.
  10. .stu
    .stu Member
    Jun 9, 2009
    586
    28
    +41
    I get that on my 50PS8000 when I go to a DTV channel, because I haven't tuned them, so I don't think it is an issue.
    Dunno about the colors thing tho.
  11. Jeton
    Jeton Member
    Nov 13, 2009
    7
    3
    +7
    I am sorry to tell you this but you bicked your TV.
    If you read the thread and the wiki it states explicitly to not downgrade if you have version 3.48 as it will brick your TV.
    You need to send the TV back to repair it. Nothing you can do.
  12. R86
    R86 Member
    Dec 6, 2009
    Is this gonna work on my LG2100 with f.ware 3.40 ?
  13. Dennis585
    Dennis585 Member
    Oct 17, 2009
    26
    3
    +16
  14. Nearos
    Nearos Member
    Dec 15, 2009
    3
    Just search in forum for 3.55 Firmware and upgrade!
    I did the same (downgrade from 3.48 to 3.15) on same tv 32LH3000.
    But now its fine!!!
  15. yglos
    yglos Member
    Dec 7, 2009
    12
    Do you know if original remote for service menu ( LG ) use the protocol RC 5 at 36 khz ?
  16. Nearos
    Nearos Member
    Dec 15, 2009
    3
    No I don't know.
  17. yglos
    yglos Member
    Dec 7, 2009
    12
    Insists that need to access the service menu without changing the firmware and found a post very interesting:
    Short translation from this forum: LCD TV LG LH2000/LH3000/LH4000/LF2510 (uključivanje DivX podrške) - Strana 15 - BENCHforum
    Poster there has LG 32LH3000 with originally installed firmware v3.24. He also has Philips universal remote SRU7140, where four digit code is needed to be entered to control particular TV brand/model. In this case, he used code 0119. After that, by pushing INFO button on Philips remote, he gets prompt for four digit password code on LG TV, to enter into service mode.
    After password prompt shows, he then uses original LG remote for entering 0000 and changing options there.
    I assume, this should work for more recent firmwares too (3.40, 3.47/8...).
    I hope, this info has some value for LG LH owners.
    Greetings,
    Bogdan
    Please check this code with your any universal remote and try enter in service menu using buttons like GUIDE or INFO.
    Then use LG TV original remote and change ONLY parameters described in tutorial.
    Please write here your results too.
    Regards
  18. bbandzz
    bbandzz Member
    Dec 18, 2009
    14
    Can anyone tell me how to check my firmware version?
    Also, Nearos, can you please give me a link for the 3.55 firmware? I could not find it in the forum.
    Thanks!
  19. Nearos
    Nearos Member
    Dec 15, 2009
    3
  20. bbandzz
    bbandzz Member
    Dec 18, 2009
    14
  21. yglos
    yglos Member
    Dec 7, 2009
    12
    Someone can acces service menu LG TV with another remote control ? ( Harmony or other )
    Please tell me what type and model.
  22. bbandzz
    bbandzz Member
    Dec 18, 2009
    14
    I used a philips universal remote.
  23. boudicca
    boudicca Member
    Apr 23, 2006
    283
    28
    +35
    Novii remote on a pda
  24. stanoh
    stanoh Member
    Mar 9, 2008
    3
    3
    Nokia E51 with Symbian Psiloc irRemote program and setting for service LG remote
  25. VANT
    VANT Member
    Nov 26, 2009
    16
    3
    USB Hack not work with US version !
  26. bbandzz
    bbandzz Member
    Dec 18, 2009
    14
    USB hack is working for US model! Just use a universal remote and it is very easy!
  27. VANT
    VANT Member
    Nov 26, 2009
    16
    3
    ok, but i mean using 3.15 FW.....
  28. bludsuka
    bludsuka Member
    Jan 11, 2010
    3
  29. Antrax
    Antrax Member
    Sep 2, 2009
    9
    Today I've downgraded from 3.40 to 3.15 and I can play from USB but now there is no sound, even when I'm watching regular TV program (IPTV). I can't get sound from USB files either, Now I'm back on 3.40 and problem is still there, in settings I didn't change nothing else only what was needed.
    I try to use restore function (7x9) but nothing happens, still no sound. I tried connecting headphones and they are working perfect.
    In AUDIO menu I have everything enabled and set to highest, what could that be?
    Can I try with USB deactivation option under USB menu?
    It is 37LH3000.
    I hope you could help me.
  30. Tinderbox (UK)
    Tinderbox (UK) Member
    Feb 5, 2007
    583
    28
    +37
    why dont you flash from v3.15 to v3.55 you will keep the usb playback feature, and it might fix your audio problem.
    make certain your tv is compatible first though, in the FAQ below.
    LG USB Port Hack - home
