LG 42LM615S Can't connect to my router
Discussion in 'LCD & LED LCD TVs' started by aklesh, Nov 23, 2012.
  1. aklesh
    aklesh Member
    Nov 23, 2012
    Hi guys,
    I just bought an LG 42LM615S 3d tv. I am very happy with it... but... I try to connect to my home network. When I plug in the ethernet connector the tv displays that a LAN cable is connected. It seraches for a while and this results in the message "Can''t connect to network" (or something similar). When I look at my routers DHCP list, there is no IP given to the tv. When I remove the cable a message is displayes on TV "LAN cable removed" (or something similar).
    I have tried the following:
    - reboot router
    - tried different sockets on my router
    - reset tv
    - tried 2 cables
    - both cables work on my laptop
    I use a Belkin Wireless 54G router (Belkin 54G Wireless Router review at Kaboodle)
    It seems that the tv "sees" that a cable in inserted, but I get a red cross (in the tv network menu) between tv and router.
    Does anybody know what the problem could be and how I can fix this??
    Thanks in advance!
