Krups Nespresso FNA243 Water problems
Discussion in 'Home Appliances' started by shinho62, Feb 18, 2012.
  1. shinho62
    shinho62 Member
    Feb 18, 2012
    3
    I took ownership of a Krups Nespresso Concept FNA243 from a family member, once i ensured all the parts were present i was off and running great coffee, however today i filled the water container, switched it on placed a capsule in the holder closed it and hit the large coffee button
    but all its does is fill the drip tray nothing comes out via the capsule
    i have removed the the silver capsule cover that pierces the capsule and tried it water does pour out, but when i put it and the spring back in nothing it just fills hot water internally
    the milk frother works great, anyone have any ideas:lease:
  2. sniffer66
    sniffer66 Well-Known Member
    May 22, 2004
    8,813
    +2,314
    Have you tried a descale yet ?
    My nespresso does some odd stuff when it needs descaling
  3. shinho62
    shinho62 Member
    Feb 18, 2012
    3
    No, i have not descaled it as yet, wanted to ask first, to ensure it was not something else:facepalm:
  4. Caskey
    Caskey Active Member
    Sep 22, 2008
    1,606
    +346
    Yeah, definitely sounds like you need to descale it. I wouldn't bother with the official expensive descaling kits. Can get oust descaler from asda for £1.50.
  5. sniffer66
    May 22, 2004
    8,813
    +2,314
    And run it through a good few times. If its badly scaled and blocked you'll need to give it a good going over
    I only ever fill mine from a Brita filter these days. It really helps
  6. shinho62
    shinho62 Member
    Feb 18, 2012
    3
    Hi as recommended i have descaled this i purchased the nespresso descaler, and ran that thorugh in also purchased the oust desclaer and ran all three sachets through a few times each, but all it does is fill the container under the cup, it still does not come through the capsule holder, any ideas
