KEF PSW 2010 Subwoofer - faulty?
Discussion in 'Subwoofers' started by GAmbrose, Nov 16, 2006.
Thread Status:
Not open for further replies.
  1. GAmbrose
    GAmbrose Member
    Jul 5, 2003
    586
    +9
    Hello all, been a while since I posted.
    About a week ago my KEF PSW 2010 Sub started playing up and it would seem to be in need of repair. When the sub detects a signal (i.e the LED changes from red to green) it emits a loud and constant humming noise which continues until you turn it off.
    Now usually I would just send it back to KEF for repair, but I bought this one from Play.com back in June 2004 and I'm pretty certain you aren't supposed to be able to buy KEF products over the internet. More worrying was that when I originally recieved the speakers and sub, the serial numbers had been scratched off all the Egg speakers which seems very dodgy. I'm not sure if it applies to the subwoofer as well.
    So will KEF repair stuff without proof of purchase? I'd rather pay £50 for them to repair it than have to buy a new subwoofer. If not, what are my options?
    Any thoughts appreciated.
    Gary A
  2. adam4478
    adam4478 Member
    Jul 25, 2006
    866
    28
    +60
    hi mate,
    had a similar problem with same sub of similar age - took the amp out of the unit and sent it back to them - fixed it with no hassle and had it back within a week - was not asked for proof of purchase (but mine does have the serial numbers!!!). give them a call on 01622672261 and speak to the guys in servicing - they're usually pretty cool and there is a history of problems with the amp in this sub from the earlier ones built... had kef/celestion equipment for many years and never had a problem with them on repairs/faults... alternatively order a new amp for the box from them (shouldnt' be too dear)... be aware thatwhen removing the amp you need to keep the internal amp to sub cable and the plastic casing from the back of the amp... they didn't send mine back and had to chase for replacements... Good luck
    Adam
    • Thanks Thanks x 1
  3. GAmbrose
    GAmbrose Member
    Jul 5, 2003
    586
    +9
    Thanks for such a prompt and helpful reply :)
    I'll check the serial number tonight and give them a call. Is it fairly easy to open it up and remove the amp?
    Gary A
  4. adam4478
    adam4478 Member
    Jul 25, 2006
    866
    28
    +60
    it's a few screws and a bit of jiggling :D ... just be gentle and it shouldn't be a problem - costs a hell of a lot less than sending the whole unit... you'll want to wrap it well i'd suggest that once the plastic back is off a bit of cardboard around the electronics, bubble wrap and tight into a box - they're pretty fragile once you remove the protective case so it's important:smashin:
  5. david.miller
    david.miller Member
    Nov 15, 2006
    172
    +12
    This is good news! My PSW 2000 subwoofer (bought as part of a KEF 2005 set from Hyperfi just under 2 years ago) has just stopped working. I'm distraught: the KEFs have been a superb purchase!
    Here's hoping it can be repaired for a reasonable cost...
    David
    • Thanks Thanks x 1
  6. GAmbrose
    GAmbrose Member
    Jul 5, 2003
    586
    +9
    Had a look for the serial number, looks like they tore the sticker off...Great.
    Do you remember if KEF needed you to provide the serial number when you sorted your one out?
    Gary A
  7. adam4478
    adam4478 Member
    Jul 25, 2006
    866
    28
    +60
    i never gave them the serial number but assume they saw it was on there when i sent it in - i wouldn't be surprised if the serial number is repeated on the inside somewhere (speculation obviously) - if not i can't imagine they'll refuse to fix/sell you a replacement - hope i'm not wrong for your sake mate:thumbsup: why not just give them a call, organise and don't mention it unless they do!!!!!
  8. Veolia
    Veolia New Member
    Oct 14, 2006
    152
    +3
    From the KEF warranty card I have:
    "Removal or defacing the serial number on any KEF Audio UK product will results in the warranty being void. KEF will not be liable to repair or replace any product(s) that meet this condition"
    :thumbsdow
    Give it a go anyway and just plead ignorance if they quesion it. Otherwise it looks like you'll have to pay for the bits rather than get them gratis.
  9. david.miller
    david.miller Member
    Nov 15, 2006
    172
    +12
    If it's more than a year old (like mine), it shouldn't matter what state the serial number's in - I'd expect them just to charge the standard £50 for replacing the appropriate bits. (KEF warranties are 1 year for active components.)
    David
  10. Bogside
    Bogside Active Member
    Sep 20, 2002
    2,768
    +278
    My sub has just developed what sounds like the same problem.
    Thanks for the advice above.
    I'll give 'em a ring and see about just sending through the amp.
    Just thought I'd piggyback the thread.:smashin:
  11. Nimby
    Nimby Active Member
    Jan 27, 2004
    9,164
    +689
    :devil: I'm just praying nobody mentions built-in obsolescence.... :devil:
  12. GAmbrose
    GAmbrose Member
    Jul 5, 2003
    586
    +9
    Just to clarify, it is the metal plate where the power lead goes in and where the controls are that I have to remove (as opposed to the actual speaker on the bottom)
    Having major trouble getting 5 screws in particular out (The ones surrounding the PSW 2010 logo)
    Gary A
  13. Member 96948
    Member 96948 Active Member
    Nov 18, 2005
    9,918
    +1,854
    You may need a 'Torx' screwdriver of the right size, but IIRC an allen key of the right size should work.
    If you have neither, what sort of a man are you!
    Russell
    PS. the panel is heavy, so the whole sub may need turning on it's back, or applying a bit of leveradge may help.
  14. AquilÆagle
    AquilÆagle Guest
    Excellent, just what I need this is. Switched on my amp one day and for some odd reason it was at full blast, gave me the fright of my life, but since then the sub makes this loud, constant humming noise. It is well out of warranty now, but if the fix is 50 notes then that is all good :)
  15. AquilÆagle
    AquilÆagle Guest
    I've taken the back off and will phone KEF on Monday to see what they say :) Would anyone who has success with this please post full details :)
  16. Qublai
    Qublai Member
    Oct 24, 2005
    157
    +11
  17. Russell_S
    Russell_S Member
    Sep 29, 2003
    128
    +10
    I had the same problem with mine last year - constant humming when switched on. I phoned Kef up and they were very helpfull. I just removed the amp panel, stuck it in a box tightly wrapped in bubblewrap and sent it off to them with a cheque for £50. At the time they didn't have any replacement panels in stock so they repaired mine and modded it to stop the same fault happening again and it was back with me within the week.
    Unfortunately, when it arrived back with me and I unboxed it the actual metal panel was bent in one corner. You could see that someone (ie. the courier) had stood on the box, probably to reach something higher, as the cardboard box was squashed at that corner as well. However, once again, Kef were great. I phoned them to explain and there was no problem, they just sent another one out to me when they had a delivery.
    All in all, great service from Kef.
  18. huntere
    huntere Member
    Dec 30, 2004
    1,510
    63
    +170
    I got this too!
    Was slightly horrified when I switched it on tonight and it buzzed like a beauty.
    Especially as I'd had everything powered off so I could change cables on Sky HD having got the dreaded HDCP error with my Pio.
    Now got this! Not a good week!
    At least it seems a pretty simple fix with KEF. I am slightly confused about the £50 payment though. I thought KEF had acknowledged the amp was less than perfect in this unit and was repairing for free irrespective of warranty.
  19. gzed
    gzed Member
    Aug 29, 2005
    71
    I have the same problem on my PSW2000 (june 2003) and also thought that this would cost me. My local shop (not cheap) quoted me £100-150 for repair last month.
    I'm glad I've seen this post. i will ring KEF tonight.
  20. gzed
    gzed Member
    Aug 29, 2005
    71
    So I rang KEF service department.
    The nice guy was quick to tell me that the power supply needed repaired especially since the subwoofer is always ON (although it goes into standby, the PSU is not in standby and wears out).
    I'll disconenct it tonight and post it tomorrow.
    It's £50 (inc tax and postage) for items older than 1 year.
  21. gzed
    gzed Member
    Aug 29, 2005
    71
    :rolleyes: I'm not good with telephone me... :rolleyes:
    Have you all put a £50 cheque when you sent your unit or did you wait for an invoice? The guy said there is a £50 fee for repair but didn't say how and when to pay.
    cheers
  22. cmc
    cmc Member
    Aug 17, 2004
    29
    3
    Hi everyone, just in the process of sending my board back to KEF after my 2010 stopped working. The engineer told me to remove the + and - leads from the board but I am not sure how to do this. I am a bit scared to yank them out!
    Any advice from anyone who has already done this would be much appreciated!
    Thx.
  23. Russell_S
    Russell_S Member
    Sep 29, 2003
    128
    +10
    They are just spade connectors for the speaker connections. Just pull them off, giving them a little sideways wiggle to loosen them a bit. Make sure you make a note of which one is on which connector so that you put them back the right way when the repaired panel comes back.
    Regards
    Russell
  24. cmc
    cmc Member
    Aug 17, 2004
    29
    3
    Thanks for your help, Russell. They just seemed really tightly attached and were refusing to slide off. Will give it another go today.
  25. gzed
    gzed Member
    Aug 29, 2005
    71
    It was the same for me. i spent 30min trying to pull them off. Gave up, came back 1 hour later and they slided off easily. :confused:
    I got my unit repaired and was back in my in home within a week.
    Great job KEF:thumbsup:
  26. IVOLIC
    IVOLIC Member
    Jan 26, 2004
    132
    +6
    Well mine acted up the other day. Same constant humming noise when the sub is on.
    Luckily for me my father-in-law is an electric guru and he told me without opening it that capacitors where the problem.
    Needless to say when we did open it one of the capacitors (there are 2 of them,12000 micorfarads) was black at the connection point with the panel.
    I am going to buy 2 new capacitors via ebay for $25 and have my father-in-law put them in.
    Hopefully all will be booming again in a few weeks!
  27. Gordie
    Gordie Guest
    Just going through the same problems with my 2010 sub. Tried phoning Ben on Monday, but had to leave a message on his voicemail - he never got back to me. Also tried speaking to someone else, but just got "everyone's on calls at the moment". I eventually got a response from someone via email to take this back to where I bought it. I explained that I now live about 800 miles from where it was purchased and after about another 4 emails, I was asked to return it to them for repair. I was asked to specifically request a quotation for repair and someone would call me with what the cost would be, but as yet I have heard nothing. I tracked the box and it was signed for on Tuesday morning first thing. I gave them a call just now to find out if my sub amp had been looked at, but was told that I couldn't speak to anyone as there was only 1 person working in the service department today and they were only accepting "accounts calls". I was then asked to try and phone back on Monday.
    I know everyone raves on about the excellent customer service that KEF has, to be honest, I'm not seeing it yet. I was sold a piece of kit that included a known problem sub. When it inevitably went wrong, they don't seem to be in a rush to solve my problem - and wanting to charge me £50.00 for the priveledge. We should not have to pay for this - regardless of when I bought it. This should not be a warranty issue.
  28. Gordie
    Gordie Guest
    Just to follow-up from my last post. Ben at KEF just called me to say that the unit has been repaired and that the capacitors needed changing and told me to basically switch it off when not in use.
    Then told me that the price for repair was £90.00 + VAT = £105.75.
    A bit steep don't you think. If I knew it was going to be as much as that, I would probably have put the rest to it and got a new one.
  29. mediamogul
    mediamogul Member
    Jan 25, 2002
    483
    +20
    I think the £90 included upgrades to all known parts that have proved un-reliable in the past and a new power supply.That was what i was told by the service dept at Maidstone yesterday.I have been there before when just out of warranty and they gave me a new amp free,they no longer keep them in stock now.They just do a bit of an upgrade.
  30. Oakey
    Oakey Member
    Aug 4, 2002
    459
    +6
    Had the same problem back in April and only just got round to arranging to send it back. Imagine my horror when I'd discovered the price had now practically doubled!!
    Sorry, but it's a complete rip off. We've seen on various threads here that Kef were repairing these for free, then they introduced a £50 fee, now it's £90!! My only guess is that the system is reaching that age where more and more of them are failing and they see it as a bit of a cash cow. A three year lifepsan for a piece of hardware that the majority of audio retailers were trying damned hard to sell at nothing less than £1000 (with the exception of Creative Audio) is pathetic.
    Not only that, but this is a blatant issue with the system, this isn't wear or tear or damage caused by a user, this is an obvious fault that a lot of owners are seeing. It's blatantly poor quality control and why should the consumers have to pay for it?
    Also, if you read threads like this:
    http://www.avforums.com/forums/showpost.php?p=5003950&postcount=39
    you'll see that one owner had his sub repaired for free, and this was at the end of June 2007!!
    Hardly seems consistent!
Thread Status:
