Just Got A 360, Wireless controller, How Do U Remove Batteries
Discussion in 'Xbox 360 Forum' started by -ScarFace-, Sep 20, 2006.
  1. -ScarFace-
    -ScarFace- Guest
    Everything is fine and the batteries slid in fine but i thought " how the hell do i replace these when they run out " i tried to pull them back out but they are deffo going nowhere, is there a way to get them out? a button? does the little removeable battery pack where you put the batteries in flip up ?
    I dont wanna try untill i know how, incase i break it.
  2. Dan_Nufc
    Dan_Nufc Member
    Oct 8, 2005
    299
    +11
    there's a little white button on top of the battery pack. You push that in and pull from the top. It's quite sturdy so dont be scared to use a bit force on it :thumbsup:
  3. -ScarFace-
    -ScarFace- Guest
    wait, i know about the big white button you press and that detaches the pack from the controller doesnt it, then you slide in your batteries n place the pack back onto the controller, i dont know how to get the batteries out of the detachable pack, once they've run out
  4. Jay
    Jay New Member
    Jun 25, 2006
    17,392
    +2,111
    They were quite stiff to come out of my controller, theres no button or anything to press, just pull them out. If there that stiff maybe use pliers as the batteries are only gonna go in the bin...you should be able to use your hands though. :thumbsup:
  5. -ScarFace-
    -ScarFace- Guest
    ohhh give us a kiss you little star !
    Pliers worked like a drea, TAKE THAT STIFF BATTERIES !
  6. RobDickinson
    RobDickinson Active Member
    Mar 8, 2001
    4,725
    +713
    Haha I have had the same issue , use rechargables, struggle every damned time lol.
  7. lightbulb
    lightbulb Member
    Feb 21, 2005
    684
    +51
    Blu-tak! :)
  8. Stinja
    Stinja Active Member
    Aug 13, 2003
    8,929
    +1,552
    I had the same issue.
    Try this; look inside the removable battery compartment and you'll see a small foam square which presses against the middle of the batteries when in place. I used a craft knife to cut/scrape it away, and presto they slide in and out now (a small shake does it). Makes using rechargable batteries much easier!
  9. plasmad00d
    plasmad00d Member
    Apr 3, 2006
    779
    28
    +49
    You get an "Achievement" if you get the batteries out :D
  10. Jay
    Jay New Member
    Jun 25, 2006
    17,392
    +2,111
    :D
  11. CAFCmatt
    CAFCmatt Guest
    Get a rechargeable battery pack, sod using AA batteries lol
  12. nathanb
    nathanb Member
    Aug 13, 2006
    177
  13. bananacat
    bananacat Member
    May 5, 2005
    500
    +14
    nice one i managed to get a p&c kit for £5 of a mte at work who was skint hahaha since then ive got Saint Row and Dead Rising for £40 bargain or what lol
