JPW AP3 Speakers
Discussion in 'Speakers' started by linods, Feb 3, 2005.
  1. linods
    linods Guest
    Hi there,
    Is anyone familiar with the old JPW AP3? I need to Know if you can match it with Exposure 2010 Integrated amp(50 W per channel) and EXposure 2010 power amp (60 W per channel)on a biamping basis or Two EXposure 2010 power amp connected as monoblock. : :)
    Thank you
    linods
  2. Beobloke
    Beobloke Member
    Aug 10, 2004
    1,295
    +65
    Absolutely brilliant! :smashin:
    I was always a fan of the P1/AP2/AP3 range - i used P1's myself for a couple of years and still regret selling them, about 7 years on!!
    The AP3's are very similar to the P1's but have a bigger cabinet and better quality drivers. The only thing to note is that they were always noted for their......er........"exuberant" treble performance and so need partnering with care if they aren't to completely destroy your ears!
    The Exposures should be OK and i'd go down the bi-amping route if i were you.
    Adam.
  3. linods
    linods Guest
    Thanks for the input :thumbsup:
