John Lewis Wall mount £25 upto 32"-52"
Discussion in 'TV & Projector Brackets & Mounts' started by mikeuk2004, Jul 3, 2007.
  1. mikeuk2004
    mikeuk2004 Guest
    If your interested in mounting your TV. I bought this from John Lewis for £25
    http://www.johnlewis.com/Audio and ...s and Connections/2120/230400621/Product.aspx
    [​IMG]
    Discount: £5 of £25 spend
    Minimum Spend: £25.00
    Promotional Code: WO851LGH555
    Its identical to the Onmimount one that sells for £100+
    It comes with hundreds of screws and fittings for any TV. Long, Short, Think, Thin screws to screw into your TV. You dont need to worry if it does not have the fittings for your TV.
    Comes with 6 bolts and plus to mount it on the wall.
    [​IMG]
    • Thanks Thanks x 1
  2. the.fantom
    the.fantom Member
    Mar 23, 2006
    60
    Damn - Out of stock ! :(
  3. doylie1984
    doylie1984 Member
    Feb 1, 2007
    600
    +23
    this is just what i'm after but mikeuk2004 what size screen have you got? has mine would be a 32" and dont really want anymetal parts showing.
    Thanks.
  4. mikeuk2004
    mikeuk2004 Guest
    Mines 46" I reckon you might see some metal on a 32". Ill measure it as John Lewis does not give this details on their site.
  5. b1g1an
    b1g1an Member
    Aug 15, 2005
    165
    +12
    Cheers Mike have one on order, much more of a bargain than those Amazon/Ebay ones.
  6. mikeuk2004
    mikeuk2004 Guest
    Ok I measured the main plate and there are as follows,
    Inches Width 31" x Height 11.5"
    CM Width 79cm x Height 29cm
    The Vertical mounts are 21" Inches or 54cm Long
  7. peetmac
    peetmac Member
    Oct 24, 2006
    68
    +3
    Hi Mike would this mount be ok for a sammy LE46M88 ???
    how did you find the fitting?? did it have bolts/screws for the back of the tv??
    thx
    pete:)
  8. Paulomeandi
    Paulomeandi Member
    Sep 7, 2003
    190
    +3
  9. N42
    N42 Member
    Nov 2, 2004
    549
    +20
    Hi can you please tell me the depth of the plasma to the wall face. Cheers
  10. Paulomeandi
    Paulomeandi Member
    Sep 7, 2003
    190
    +3
    John lewis are going to deliver mine on monday so by tuesday i should be able to tell you.
  11. N42
    N42 Member
    Nov 2, 2004
    549
    +20
    Excellent mate, cheers
  12. Paulomeandi
    Paulomeandi Member
    Sep 7, 2003
    190
    +3
    If you look at the picture of the mount above it stands 6.5cm off the wall. Thats not inc any spacers or anything else. I only just unboxed it.
  13. N42
    N42 Member
    Nov 2, 2004
    549
    +20
    Hi mate, thanks for the measurements. Let us know how you get on fitting it.
  14. Paulomeandi
    Paulomeandi Member
    Sep 7, 2003
    190
    +3
    Cant fit it today. Lack of a size 12 drillbit means ill have to wait till thrusday at best now.
