iPhone 4 Screen Flicker Problem?
Discussion in 'iPhone Forum' started by RockSteddie, Jun 25, 2010.
  1. RockSteddie
    RockSteddie Member
    Mar 26, 2005
    1,063
    63
    +109
    Has anyone else noticed a slight flicker when scrolling from the 2nd apps page back to the Home screen? Mine does and it's very distracting and I've a feeling it's not meant to happen. Didn't happen on my 3GS and my mate's iPhone4 doesn't suffer either. And to top it all I have the dreaded yelllow spots, though they may fade over time supposedly :confused:.
    Won't even be able to take it back for a replacement for a while I guess due to stock shortages :rolleyes:
  2. Meridius
    Meridius Active Member
    Dec 23, 2002
    3,595
    +106
    i noticed this problem in apples store on there demo models but i dont know if its the software version 4 or the phone 4 anyone noticed thios on a 3gs with version 4 software
  3. RockSteddie
    RockSteddie Member
    Mar 26, 2005
    1,063
    63
    +109
    Yeah me, I updated to IOS4 on my 3GS and no flicker. So am I right in thinking it's not meant to happen?
    I can't check with my friends phone until this evening.
  4. Meridius
    Dec 23, 2002
    3,595
    +106
    Just tried 4 demo models and 2 different shops and they all flicker when u go to the home screen from left to right but if u use the home button it does not do it or if you go to the third screen of apps it does not do it
    and if the problem is not on the iso4 software then this is another fault with the new iPhones Jesus what's going on I am standing here able to get 2 but hs is puting me right off
  5. muffins
    muffins Active Member
    Feb 1, 2008
    2,867
    +265
    No flicker on my iPhone 4. I guess I'm blessed. No yellow screen, no flicker, no reception issues nothing but a grade A product.
  6. BadBoy_R
    BadBoy_R Member
    Nov 14, 2006
    495
    +23
    Mine does this, however I never noticed it until I read this thread :S
  7. mrash
    mrash Member
    Jun 30, 2009
    735
    28
    +60
    snap. I feel for those that have the problems though
  8. tigermad
    tigermad Active Member
    Jan 2, 2004
    4,085
    +140
    Try other wallpapers. Only seems to do it on the raindrop one.
  9. leebroath
    leebroath Active Member
    Aug 7, 2005
    3,712
    +459
    Mine does this but as said above, I never noticed until someone pointed it out
    not a biggy
    Nope it happens with the big wave shot also, in fact it happens with them all
  10. Sharpy76
    Sharpy76 Active Member
    Mar 2, 2009
    4,193
    +1,002
    Ive tried it with the Raindrop wallpaper and without and mine is fine.
  11. tigermad
    Jan 2, 2004
    4,085
    +140
    It's only the slightest of flickers. It is not really that noticeable.
  12. leebroath
    Aug 7, 2005
    3,712
    +459
    It's not that noticeable at all....certainly wouldn't be storming back to the Apple store for a refund anyway! lol
  13. muffins
    Feb 1, 2008
    2,867
    +265
    Just tried the rain drop wallpaper as I replaced it as soon as I got my phone. Still no flicker.:blush:
  14. leebroath
    Aug 7, 2005
    3,712
    +459
    Could be my eyes lol
    they aren't what they used to be o_O
  15. Meridius
    Dec 23, 2002
    3,595
    +106
    It's not the point it should not be doing it full stop
  16. leebroath
    Aug 7, 2005
    3,712
    +459
    Take it back for a refund then :)
  17. mitchellsx
    mitchellsx New Member
    Jul 30, 2008
    509
    +9
    Yeh just noticed mine does it when switching screens
  18. RockSteddie
    RockSteddie Member
    Mar 26, 2005
    1,063
    63
    +109
    Sorry for making people notice this :rolleyes:
    It's just I pick things up like this very quickly and it stood out to me straight away . Anyway as people say it's not a big issue and it's not something I would return the phone for unless it was oficially recognised as a fault by Apple or something.
    The yellow spots are more of an issue for me but I know if they don't fade as suggested (don't seem to have after a day and a bit's use) that Apple would replace the handset without argument as it's clearly a fault with the screen.
  19. SteveU30
    SteveU30 Active Member
    Oct 2, 2008
    2,576
    +301
    Have you tried turning the auto-brightness off?
    I turned it off straight away as the screen was far too dull for my liking!
    Settings>Brightness>Auto Brightness - OFF
  20. oymd
    oymd Member
    Oct 11, 2005
    526
    +16
    yep...it certainly does this...
    not an issue though...didn't really notice it till i read this post...
    mine is a 32GB one...
  21. stoomc
    stoomc Active Member
    Mar 30, 2006
    4,053
    +296
    All LCDs flicker so if you are not seeing you are just not as sensitive to it as others. A good solution is to turn the brightness up a notch. Having it at low light will highlight the flicker more.
    Hope this helps.
  22. Meridius
    Dec 23, 2002
    3,595
    +106
    Tried all the brightness settings and still the same and that's on 5 demo models
    the thing is to only happens once at that's when u swip to the home screen. Even using the home button does not do it so it must be a firmware problem but as I don't own one yet it would be best for owners who have this problem to report it to apple just in case.
  23. leebroath
    Aug 7, 2005
    3,712
    +459
    Stop Hold up !! I know what is the problem :)
    The only reason were getting that sort of "flicker" is because the page sort of goes a tiny bit into the left screen which is the spotlight page....therefore it thinks the page is away to get dark...but no it doesn't as it's pinged back to the normal first page (this only happens in like a millisecond)
    If you sort of slide to the left a bit from the first page to the spotlight search you will see the screen sort of goes dark, let it go and it brightens up again
    that could be the flicker everyone is thinking they have ????
  24. Meridius
    Dec 23, 2002
    3,595
    +106
    its possable i will try to do it real slow and see if it stops it but why does the 3gs not do this ?
    a strange one
  25. sneeks
    sneeks Active Member
    Jan 9, 2007
    3,711
    +408
    that's the only flicker I've ever seen but it's not a flicker as such and simply the wallpaper fades to a dark background when you scroll towards Spotlight. This is a new effect added now that Apple support custom wallpapers, prior to this the background was black anyway.
  26. leebroath
    Aug 7, 2005
    3,712
    +459
    That's what I said :rolleyes::rolleyes: lol
  27. sneeks
    Jan 9, 2007
    3,711
    +408
    I was confirming that I agree with you :thumbsup:
  28. leebroath
    Aug 7, 2005
    3,712
    +459
    lol cool ;):thumbsup:
    that wraps that small problem up
