iPad 3 [Rumour Thread]
Discussion in 'iPad Forum' started by Rock Da Bass, Dec 30, 2011.
Thread Status:
Not open for further replies.
  1. Peew971
    Peew971 Member
    Aug 14, 2007
    1,765
    +194
    I'd say he should get an original Xoom at a good price and update it to Ice Cream Sandwich. Unless money isn't an issue and he gets the Transformer Prime. One thing I like about these is the UI and if it wasn't for app selections I would have picked one over my iPad.
  2. bpsmith
    bpsmith Active Member
    Jan 8, 2010
    7,573
    +709
    Back on topic.
    Quad core rumour shots from testing look interesting!?!
  3. Razor
    Razor Well-Known Member
    Dec 15, 2004
    37,050
    +9,161
    The ridiculous names that they give android products/OS just make me laugh. :rotfl:
    Ice Cream Sandwich
    Transformer Prime
  4. Razor
    Dec 15, 2004
    37,050
    +9,161
    Have you got a link? :)
  5. Peew971
    Peew971 Member
    Aug 14, 2007
    1,765
    +194
    How much of dual core is used in iPad 2 that you already need quad core? I mean you can still run pretty much any app on the original iPad including Infinity Blade II and GTA 3 so what's the point of quad core now rather than say, in the iPad 4. It feels like it would be just for the specs sheet at this point, most developers would develop for all the iPads, not just the quad core ones.
  6. FallOutBoy
    FallOutBoy Active Member
    Mar 12, 2008
    4,260
    +417
    Presumably to give it the power to run that lovely new retina display whilst still maintaining a nice snappy speed at all times!
    Older iPads will still run the apps but the new version will run them in higher res, so the quad-core would be needed.
  7. Peew971
    Peew971 Member
    Aug 14, 2007
    1,765
    +194
    So yeah, not much point unless you're desperate for retina display. The only thing I'm interested in is whether or not they finally modernise the UI, anything else might just be a bit of a gimmick.
  8. Azzin
    Azzin Well-Known Member
    Nov 5, 2005
    23,860
    +3,078
    • Thanks Thanks x 1
  9. Azzin
    Nov 5, 2005
    23,860
    +3,078
    We've not long moved to iOS5, so there won't be a massive UI overhaul until iOS6, which would presumably arrive later this year.
  10. Razor
    Dec 15, 2004
    37,050
    +9,161
    Obviously it depends on how the ipad is programmed but surely this would be the job of the gpu rather than the cpu?
  11. Razor
    Dec 15, 2004
    37,050
    +9,161
  12. RobM
    RobM Well-Known Member
    Dec 29, 2006
    13,118
    +2,185
    Multi-core CPU's aren't just about horsepower and processing ability. If the OS and applications are developed to correctly use the processor cores available, you can see massive improvements in battery life, heat, multitasking etc as well as sheer number crunching.
    For instance, if you're just tinkering with settings, checking email, that sort of light use, the OS can shut down three of the four cores and still offer a good experience, but with a massive reduction in battery life and heat. Do something more intensive and other cores are brought into life to cater for it. If the OS supports it, you can also have different threads running on different cores to spread the load and ensure one App doesn't hinder the performance of any others. Background tasks for instance run on Zero, leaving the other three for foreground applications.
    So four lower power cores (in terms of clock speed and voltage) can improve all areas over and above single and dual-core processors.
    It's not all about horsepower :)
  13. FallOutBoy
    Mar 12, 2008
    4,260
    +417
    What RobM said lol :thumbsup: and also, surely the quad core would help to power the more powerful gpu for handling the high res display too, along with enhanced battery life, heat management etc :smashin:
  14. Razor
    Dec 15, 2004
    37,050
    +9,161
    I know its slightly different but thats not really how it works with pc's extra cores do no benefit gpu performance if the core speeds are the same. If the core speeds are higher on these new cpus and a new more powerful gpu is used then the slower core speed may bottle neck the gpu.
    Assuming the clock speeds are the same the 2 extra cores that a quad core cpu will bring would only really help gpu performance if there were dual gpus being used.
    This extra screen res will definitely need more gpu power, is there any word on a gpu upgrade?
    Its going to be interesting to see the final specs and where it benefits the performance. I think that a quad core cpu will help with apps that heavily tax the cpu like video/music editing, and strategy games. It will also help with multitasking.
  15. chukwe
    chukwe Active Member
    Aug 15, 2009
    3,916
    103
    +310
  16. bpsmith
    Jan 8, 2010
    7,573
    +709
    This is old and what I posted about days ago. Subsequently linked to in this thread afterwards by somebody else. Did you read the thread by any chance?
  17. chukwe
    Aug 15, 2009
    3,916
    103
    +310
    I didn't know it's old. Sorry
  18. AndrewH13
    AndrewH13 Active Member
    Jan 5, 2004
    10,534
    Media:
    Albums:
    +1,630
  19. Azzin
    Nov 5, 2005
    23,860
    +3,078
  20. AndrewH13
    Jan 5, 2004
    10,534
    Media:
    Albums:
    +1,630
    No, but mainstream press quoting it. Thought it might be of interest to some if not you.
  21. Azzin
    Nov 5, 2005
    23,860
    +3,078
    Sorry, didn't mean to sound harsh, there's still no "news" there.
    Plus-it's What HiFi... ;-)
  22. Kev12
    Kev12 Active Member
    Feb 7, 2002
    3,672
    +312
    Magazine snob :)
  23. Azzin
    Nov 5, 2005
    23,860
    +3,078
    Not really, I just don't class them as a reliable source of Apple/iPad information.
  24. Peew971
    Peew971 Member
    Aug 14, 2007
    1,765
    +194
    Sorry I'm too lazy to link but according to The Verge the iPad 3 will be very similar in design to the iPad 2 and sport dual core rather than quad core. In line with what I find logical.
  25. bpsmith
    Jan 8, 2010
    7,573
    +709
    I read that too, although the Dual Core chip is said to be significantly faster.
  26. Azzin
    Nov 5, 2005
    23,860
    +3,078
  27. dr no
    dr no Active Member
    Mar 30, 2004
    4,912
    +826
    I think its all more or less falling into place now:
    faster CPU - likely dual-core as opposed to quad-core
    faster GPU
    better camera - both front and rear facing - I'd guess 5MP rear
    higher resolution - not necessarily at the level of retina display density but higher
    same shape/size - more or less as smart covers are likely compatible - possible a mm thicker
    bigger battery but same battery life at best - due to the hungrier display and processing
    same storage - 128gb would be nice
    March release - 2nd week in the US/ 3rd week in UK
    Cost - most likely same as it currently is
    Thats all I can think of for now.
  28. WozzaTT
    WozzaTT Member
    Jul 28, 2007
    398
    +30
    If that's accurate I'm not sure I'll 'upgrade' from the 2. Only thing I'm really interested in is a higher resolution screen but it would have to be significantly better than on the 2.
  29. dr no
    dr no Active Member
    Mar 30, 2004
    4,912
    +826
    I'll upgrade solely for the resolution.
    It is looking/rumoured to be 2048x1536 so I would be very happy with that.
    I would prefer it to be a lot lighter but that is very unlikely.
  30. WozzaTT
    WozzaTT Member
    Jul 28, 2007
    398
    +30
    Is that a fair bit better than on the iPad 2? If so, I'll upgrade too - looking at photos on the iPad is one of the main uses I have for it.
Thread Status:
