Intel Core i3-2120 only running at 3.1GHz
Discussion in 'Desktops' started by brookheather, Feb 18, 2012.
  1. brookheather
    brookheather Active Member
    Nov 20, 2005
    4,798
    +885
    I've fitted an Intel Core i3-2120 (3.3GHz) to a Foxconn H67MP-V motherboard but strangely the System info in Control Panel says it is only running at 3.1GHz and this is confirmed by CPU-Z when running a heavy load. Anyone know why the cpu is being limited to 3.1GHz? In the UEFI it shows max processor speed as 3300MHz so that seems fine...
  2. Badger0-0
    Badger0-0 Well-Known Member
    May 30, 2005
    20,591
    +2,008
    I've got an i3 2100 with a Foxconn H67 board which also runs at 3.1 ghz.
    My money says the bios is out of date, but there's been no update since this time last year.
    I don't think I'll be bothering with low end Foxconns again :thumbsdow
    As for their website :thumbsdow
  3. brookheather
    Nov 20, 2005
    4,798
    +885
    I am running the latest UEFI version - strangely with the original shipping version a Core i3-2100 was showing as 3.3GHz instead of 3.1GHz!
    On a more positive note the PC is now using much less power at idle than the previous Athlon X2 250 - so much less in fact that my "Intelliplug" kept thinking the PC had gone to sleep and turned off my screen and speakers - had to reset the "Intelliplug".
