Importing itunes library to mediamonkey
Discussion in 'Computer Software & Operating Systems' started by supergeek, Aug 21, 2008.
  1. supergeek
    supergeek Member
    Sep 7, 2007
    1,217
    48
    +30
    converting to media monkey because im tired of itunes hogging all of my ram, does anyone know how to replicate my whole itunes library onto mediamonkey? The songs are scattered all over my pc, so was wondering if there was a way of saving it as a playlist or something and then opening in mediamonkey? thanks
  2. pixelpixel
    pixelpixel Active Member
    Jul 2, 2005
    12,512
    Media:
    Albums:
    +1,815
    Never tried to export as a playlist.....just tried and it don't work. I remember when running media money for the first time that it asks do you want to import winamp / media player / itunes into it.
    Maybe there is a setting that can be changed to get it to pop up again or even a quick uninstall.
    I use winamp and do a custom install. Its the basic setup. I also have media monkey and itunes and have no issues with either.
  3. Steven
    Steven Senior Moderator
    Feb 1, 2005
    35,548
    +5,501
    Surely you could just do a scan of your whole HD with MM for music?
    Or better yet put all your music in one place and then do the MM scan ;)
