Humax HD-FOX T2 HD Receiver Master thread [Part One]
Discussion in 'Freeview Forum' started by Stu-13, Feb 13, 2010.
Thread Status:
Not open for further replies.
  1. Oggie
    Oggie Active Member
    Jul 11, 2007
    7,200
    +613
    Mine arrived today and gotta say I'm very pleased. Yes my tv's tunner is a bit better for SD channels but this was expected. Have not updated firmware as waiting for HDD to arrive, love the way lipsync can be adjusted. Overall great buy :thumbsup:
  2. Costas
    Costas Member
    Jan 14, 2003
    1,646
    63
    +122
    It is fine with mine.... it does not take longer to pause live TV
  3. snozski
    snozski Member
    Apr 19, 2010
    27
    3
    Hi guys
    Just installed the update, was wondering what size external drive you recommend ? I got no idea what size recorded programs take up ? . I
    know its a bit like asking how long is a piece of string, however I'd be interested to know what size you guys been using.
    Is 500gb enough ?
    Just get a western digital elements ?
    TIA
    Steve
  4. kbfern
    kbfern Well-Known Member
    Aug 17, 2002
    13,896
    +2,909
    I use a 1TB western elements from PC world £53.A 500gb is about £45 so get the bigger drive you won't regret it.
    So far the most programmes I have had on it were about 25, a mix of 2hr films and 1hr programmes and it still had 700gb free.
    • Thanks Thanks x 1
  5. lbear
    lbear Active Member
    Mar 9, 2010
    2,118
    83
    +336
    Your box will probably pick it up automatically as soon as you power up and ask you if you want to install. This takes about 20-30 minutes so you may want to power off and power on later tonight and leave it to do its thing. It will also do a complete retune. The download variation was for us impatient types who have been waiting for the PVR function since we got them ages ago.
    I have posted as a .pdf the new icons you get. See a few posts back.
    The system takes up 20Gb so anything above that can be used for recording. Humax bundle a 160Gb external drive with the "revision 1" version. 500Gb drives go from about £35 for a desktop version with a power supply. This will avoid worrying about the power drain on the USB port.
    It really depends if you intend archiving on the hard drive - entire series or the films shown over Christmas for example. Ideally, you should delete once you have finished watching as much as possible, just like any PVR.
    Of course you may also wish to transfer your video, photo and audio files later but you will need (as far as have been able to work out) to do this under Linux as Windows will not recognise the file system.
    >>> All
    Anybody tried using a USB hub to access two drives and transfer files yet??
    I notice the "Network" setup option has now become "Internet" but the portal button is not yet functioning.
    • Thanks Thanks x 2
  6. brookheather
    brookheather Active Member
    Nov 20, 2005
    4,837
    +889
    • Thanks Thanks x 1
  7. r16pab
    r16pab Member
    Feb 17, 2010
    10
    Again Thanks (lbear)for the icons. I got beta version at the end of august 1 month before most, through support, And had to test for a month. But new version seems to be slightly different from beta as gsod (green screen of death has gone). Thanks Seems to be working ok for me with everthing i throw at it. Recommend download from www.humaxdigital.co.uk as it take sabout 30 mins to come down over the air. I never had to rescan channels and everything was the same as i left it, good job as i pick up 3 different transmitters and its a nightmare to tune.
  8. lbear
    lbear Active Member
    Mar 9, 2010
    2,118
    83
    +336
    A 500Mb Hitachi is £40 from Comet. Currys digital shops (part of the same Dixons Retail Group as PC World) were doing it for the same but I think have now stopped it as a "back to school special".
  9. fred67
    fred67 Member
    May 5, 2003
    169
    +10
    hmmm I still cannot pick up any HD channels! Have upgraded firmware to the latest but still no BBCHD etc.
  10. pretri
    pretri Member
    Jun 13, 2009
    160
    28
    +33
    Are you sure you are pointing to Blackhill?
    If you go to Menu, Settings, System, Signal Detection, then right arrow on the wheel you get a list of channels
    41, 44, 47, 51, 55, 65 are SD, then 59 is HD. Check what the strength and quality are on each channel.
  11. fred67
    fred67 Member
    May 5, 2003
    169
    +10
    Hi I only have channels 23,26,29,33,39,41 and 42! Signal strength is approximately 31% with 100% quality.
  12. pretri
    pretri Member
    Jun 13, 2009
    160
    28
    +33
    those are the channels for Craigkelly, HD broadcasts are not available from there until next year.
  13. fred67
    fred67 Member
    May 5, 2003
    169
    +10
    thanks petri-any idea how i get it to see the blackhill transmitter?
  14. pretri
    pretri Member
    Jun 13, 2009
    160
    28
    +33
    Hi fred67, you would need to realign the aerial to point to Blackhill, I think you said it was in the loft?
    The DTG :: Industry site will give you the bearing to use if you enter your postcode and house number. Maybe it will also show if there was a reason for using Craigkelly instead of Blackhill.
    • Thanks Thanks x 1
  15. fred67
    fred67 Member
    May 5, 2003
    169
    +10
    Hi petri
    Yeah the aerial is in the loft but have no idea o fhow to adjust it to the correct angle-and suggestions?
  16. pretri
    pretri Member
    Jun 13, 2009
    160
    28
    +33
    Craigkelly is roughly northeast of Livingston, whereas Blackhill is to the west, so the exact angle will depend on where you are. But you need to physically swivel the aerial to point west.
    If you PM me your postcode and house number I'll look them up on the dtg site for you and give you the angle. You'd need a compass though to be reasonable accurate.
  17. halfwave
    halfwave Member
    Nov 5, 2010
    2
    I have a new Fox T2 from the Ebay link in an earlier post, and it absolutely stop on. I have successfully recorded and transferred a standard definition file from the USB hard disk to my PC but so far I have not been able to find any program that will either play or convert the file. I have read other posts that refer to the file being a M2TS format and I have tried TS Doctor which only tells me the PTM is invalid. Are there any PC programs that can convert these files to a playable format?
  18. lbear
    lbear Active Member
    Mar 9, 2010
    2,118
    83
    +336
    Blimey well done! I presume you must be using a form of Linux to read the hard drive? I know the DRM means you cannot play HD files on anything other than the original box.
    Have you tried the player program VLC? This will play about anything thrown at it, is free, and has versions for Windows, Mac and Linux. Download from VideoLAN - VLC media player as there are several sites that hijack the name to sell services or even the program itself.
    It will not provide you with a work-around if there is a DRM issue with SD files.
  19. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,725
    163
    +3,096
    SD should be a pretty standard transport stream file. It would be pretty surprising if vlc player can't play it back or videoredo TV Suite can't edit it and burn to dvd.
    IF you can put a small clip on a fs share site I will have a play to see what's possible.
    You can also try the free DVDflick to see if it accepts the files and burn to dvd
  20. brookheather
    Nov 20, 2005
    4,837
    +889
    I believe the Humax encrypts ALL SD and HD recordings on the hard drive - you cannot play the files directly from the hard drive - you must export them to another drive which will will unencrypt the SD recording and then it can be played in VLC etc.
    - Simon.
  21. everett_psycho
    everett_psycho Active Member
    Nov 20, 2009
    5,347
    +1,027
    if i ever get time (looks doubtful for a while though i'm afraid) i'm trying to get my old PC running linux and will see about getting you guys some files to play with from it. It's being a bit of a pup to install it though and driving me mad so it might be a while :(
  22. halfwave
    halfwave Member
    Nov 5, 2010
    2
    Hi yes I found a utility (Ext2Read) that allows windows 7 to read the PVR hard drive. I have tried VLC but it cannot open the .ts files.
  23. grahamlthompson
    Aug 3, 2006
    18,725
    163
    +3,096
    Why would they bother with unecessary processing ?
    Have you tried connecting the drive to a linux booted PC to transfer the files. A Foxsat-hdr records SD in the clear.
  24. pretri
    pretri Member
    Jun 13, 2009
    160
    28
    +33
    I've just tried it with a short clip of lunchtime news from BBC1 SD, transferred through a Ubuntu virtual PC to windows. VLC cant display the clip, DVD Flick gives an error.
    I dont know if it's encryption or just the format.
  25. grahamlthompson
    Aug 3, 2006
    18,725
    163
    +3,096
    It's possibly a non standard header and vlc does not find the video data. Seems odd that a usb transfer works though. Very strange :confused:
    May be Humax decided to encrypt everything for convenience and unscramble it for usb transfers as already said. Have you got videoredo to try that ?
  26. pretri
    pretri Member
    Jun 13, 2009
    160
    28
    +33
    I dont have videoredo but it would be interesting to know why it doesn't work. I could PM you a link to dropdox to download the file if you want to try it.
  27. brookheather
    Nov 20, 2005
    4,837
    +889
    Yes this is what I did - I upgraded my 500GB drive to 2TB and transferred the files to the new drive and some to my PC drive as well. I was not able to play any of the SD or HD files on my PC. They may not be encrypted as such - just a non-standard format but in any case you cannot use VLC to directly play the recorded SD files.
    - Simon.
  28. grahamlthompson
    Aug 3, 2006
    18,725
    163
    +3,096
    Yes I would love to have a play out of sheer curiousity :D
  29. grahamlthompson
    Aug 3, 2006
    18,725
    163
    +3,096
    Have to concur there is something very strange about the file. Nothing I have will open it (amongst others TSmuxergui and video-redo). It can't be just the video data is scrambled. For instance vlc will open a scrambled H264 .ts file from a Foxsat-hdr and play it back but of course the picture is a complete mess. When I get time I will try and look at what's going on.
    • Thanks Thanks x 1
  30. nwhitfield
    nwhitfield Active Member
    Dec 15, 2005
    1,628
    83
    +261
    I'd say the whole file is probably encrypted, likely using AES or something like that. It's perhaps simplest (and avoids any bugs accidentally failing to encrypt) to do that to everything, and then actually apply the content controls via the user interface when you try to copy material off the box.
    I suspect there's probably even hardware within the box that will handle this, as it's likely to be a common requirement for a lot of kit.
Thread Status:
